1.5SMCJ15A
1.5SMCJ15A
    MULTICOMP
    SMC(DO-214AB)
1.5SMCJ15A 数据手册
SMBJ / 1.5SMCJ Series Surface Mount Voltage Suppressors Features: •  •  •  •  •  •  •  Transient Voltage Suppressor For surface mounted applications in order to optimise board space Low profile package Built-in strain relief Glass passivated junction Excellent clamping capability Low inductance Repetition Rate (duty cycle) : 0.05% (1.5SMCJ) 0.01% (SMBJ) •  Fast Response Time : Typically less than 1 ps from 0 volts to BV min. •  Typical Id less than 1μA above 10V •  High Temperature Soldering : 250°C / 10 seconds (1.5SMCJ) 260°C / 10 seconds (SMBJ) Dimension Table: Dimensions Rating (W) Type A (mm) B (mm) C (mm) 600 SMBJ 2.11 4.57 3.94 1,500 1.5SMCJ 3.15 7.11 6.22 Mechanical Data Case : J EDEC DO-214AB moulded plastic over passivated junction (SMBJ) JEDEC DO-214AA moulded plastic over passivated junction (1.5SMCJ) Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 Polarity : Indicated by cathode band Standard Packaging : 1  2 mm tape per (EIA 481) (SMBJ) 16 mm tape per (EIA 481) (1.5SMCJ) Weight :0  .003 ounce, 0.093 g (SMBJ) 0.007 ounce, 0.21 g (1.5SMCJ) SMB/DO-214AA Dimensions : Inches (Millimetres) www.element14.com www.farnell.com www.newark.com Page 22/01/16 V1.0 SMBJ / 1.5SMCJ Series Surface Mount Voltage Suppressors 1.5SMC/DO-214AB Dimensions : Inches (Millimetres) Maximum Ratings and Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified Symbol Value Units Peak pulse power dissipation on 10 / 1,000μs waveform (Note 1 and 2 - Fig 1) Rating Pppm Minimum 600 Watts Peak ulse current on 10 / 1,000μs waveform (Note 1 - Fig 3) Ippm - Amperes Peak forward surge current 8.3 ms single half sine-wave superimposed on rated load (JEDEC method - note 2 and 3) Ifsm 100 Amperes Tj, Tstg -55 to +150 °C Operating junction and storage temperature range Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25°C per Fig. 2 2. Mounted on 8mm2 copper pads to each terminal (1.5SMCJ) Mounted on 5mm2 (0.013mm thick) land areas (SMBJ) 3. Measured on 8.3ms, single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minutes maximum Maximum Ratings and Characteristic Curves www.element14.com www.farnell.com www.newark.com Page 22/01/16 V1.0 SMBJ / 1.5SMCJ Series Surface Mount Voltage Suppressors www.element14.com www.farnell.com www.newark.com Page 22/01/16 V1.0 SMBJ / 1.5SMCJ Series Surface Mount Voltage Suppressors Uni-Directional 600 Watt Surface Mount TVS Device Marking Code Stand-off Voltage Vrm (V) Breakdown Voltage Vbr (V) Min. at IT Breakdown Voltage Vbr (V) Max. at IT Test Current Itest (mA) Max. Clamping Voltage Vclamp (V) Peak Pulse Current IPP (A) Part Number KE 5 6.4 7.25 10 9.2 65.2 SMBJ5.0A KP 7.5 8.33 9.58 12.9 46.5 SMBJ7.5A LE 12 13.3 15.3 19.9 30.2 SMBJ12A LM 15 16.7 19.2 24.4 24 SMBJ15A LZ 24 26.7 30.7 38.9 15.4 SMBJ24A MK 30 33.3 38.3 48.4 12.4 SMBJ30A 1 Uni-Directional 1,500 Watt Surface Mount TVS Device Marking Code Stand-off Voltage Vrm (V) Breakdown Voltage Vbr (V) Min. at IT Breakdown Voltage Vbr (V) Max. at IT Max. Clamping Voltage Vclamp (V) Peak Pulse Current IPP (A) Part Number GDE 5 6.4 7.25 9.2 163 1.5SMCJ5.0A GDG 6 6.67 7.67 GDV 9 10 11.5 10.3 145.6 1.5SMCJ6.0A 15.4 97.4 1.5SMCJ9.0A GEE 12 13.3 15.3 19.9 75.3 1.5SMCJ12A GEM 15 16.7 19.2 GEX 22 24.4 28 24.4 61.5 1.5SMCJ15A 35.5 42.2 1.5SMCJ22A GFM 33 36.7 42.2 53.3 28.1 1.5SMCJ33A GFX 48 53.3 61.3 77.4 19.4 1.5SMCJ48A Test Current Itest (mA) 10 1 Uni-Directional 600 Watt Surface Mount TVS Device Marking Code Stand-off Voltage Vrm (V) Breakdown Voltage Vbr (V) Min. at IT Breakdown Voltage Vbr (V) Max. at IT Test Current Itest (mA) Max. Clamping Voltage Vclamp (V) Peak Pulse Current IPP (A) Part Number AE 5 6.4 7.25 10 9.2 65.2 SMBJ5.0CA AP 7.5 8.33 9.58 12.9 46.5 SMBJ7.5CA 19.9 30.2 SMBJ12CA 24.4 24 SMBJ15CA BE 12 13.3 15.3 BM 15 16.7 19.2 BZ 24 26.7 30.7 38.9 15.4 SMBJ24CA CK 30 33.3 38.3 48.4 12.4 SMBJ30CA 1 www.element14.com www.farnell.com www.newark.com Page 22/01/16 V1.0 SMBJ / 1.5SMCJ Series Surface Mount Voltage Suppressors Uni-Directional 1,500 Watt Surface Mount TVS Device Marking Code Stand-off Voltage Vrm (V) Breakdown Voltage Vbr (V) Min. at IT Breakdown Voltage Vbr (V) Max. at IT Max. Clamping Voltage Vclamp (V) Peak Pulse Current IPP (A) Part Number BDE 5 6.4 7.25 9.2 163 1.5SMCJ5.0CA BDG 6 6.67 7.67 BDV 9 10 11.5 10.3 145.6 1.5SMCJ6.0CA 15.4 97.4 1.5SMCJ9.0CA BEE 12 13.3 15.3 19.9 75.3 1.5SMCJ12CA BEM 15 16.7 19.2 BEX 22 24.4 28 24.4 61.5 1.5SMCJ15CA 35.5 42.2 1.5SMCJ22CA BFM 33 36.7 42.2 53.3 28.1 1.5SMCJ33CA BFX 48 53.3 61.3 77.4 19.4 1.5SMCJ48CA Test Current Itest (mA) 10 1 Part Number Explanation: Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 22/01/16 V1.0
1.5SMCJ15A 价格&库存
很抱歉,暂时无法提供与“1.5SMCJ15A”相匹配的价格&库存,您可以联系我们找货
