2MT3012-W03300
2MT3012-W03300
    MULTICOMP
2MT3012-W03300 数据手册
Waterproof M12 Connectors Panel, Female, Solder Type, Rear Mount Dimensions: Millimetre Connector Type Current Rating Contact IP Rating 3 5A 4 IP 67 & IP 68 5 2A 8 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof M12 Connectors Panel, Female, Solder Type, Front Mount Dimensions: Millimetre Connector Type Current Rating Contact IP Rating 3 5A 4 IP 67 & IP 68 5 2A 8 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof M12 Connectors Male Straight Plug, Molding Type, PVC Cable Dimensions: Millimetre Connector Type Current Rating Contact IP Rating 3 5A 4 IP 67 5 2A 8 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof M12 Connectors Male R/A Plug, Molding Type, PVC Cable Dimensions: Millimetre Current Rating Contact IP Rating 3 5A 4 IP 67 5 2A 8 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof M12 Connectors Specifications Standard Value Description Panel Mount, Molded with Cable Current Rating 2A, 5A Pin Configuration 3, 4, 5, 8 Contacts Material Contact : Copper Alloy, Gold Plated Connector Body : Nylon+GF or TPU Shield : Copper Alloy, Nickel Plated Temperature Range Cable : -20°C to + 80°C (PVC) -25°C to + 90°C (TPU) Connector Body : -25°C to 90°C IP Rating IP67 and IP68 Contact Resistance ≤10mΩ Insulation Resistance ≥100MΩ at DC 500V Durability 500 cycles Minimum Breakdown Voltage ≥AC 500V/1 Minute Corrosion 48 Hours Salt Spray Contact Part Number Table Description Part Number SOCKET, PANEL, REAR MNT, 5A, 3 WAY 2MT3000-W03300 SOCKET, PANEL, REAR MNT, 5A, 4 WAY 2MT3000-W04300 SOCKET, PANEL, REAR MNT, 5A, 5 WAY 2MT3000-W05300 SOCKET, PANEL, REAR MNT, 5A, 8 WAY 2MT3000-W08200 SOCKET, PANEL, FRONT MNT, 5A, 3 WAY 2MT3002-W03300 SOCKET, PANEL, FRONT MNT, 5A, 4 WAY 2MT3002-W04300 SOCKET, PANEL, FRONT MNT, 5A, 5 WAY 2MT3002-W05300 SOCKET, PANEL, FRONT MNT, 5A, 8 WAY 2MT3002-W08200 CABLE ASSY, PLUG-FREE, PVC, 3WAY, 1M 2MT3012-W03300 CABLE ASSY, PLUG-FREE, PVC, 4WAY, 1M 2MT3012-W04300 CABLE ASSY, PLUG-FREE, PVC, 5WAY, 1M 2MT3012-W05300 CABLE ASSY, PLUG-FREE, PVC, 8WAY, 1M 2MT3012-W08200 CABLE ASSY, PLUG-FREE, R/A, 3WAY, 1M 2MT3013-W03300 CABLE ASSY, PLUG-FREE, R/A, 4WAY, 1M 2MT3013-W04300 CABLE ASSY, PLUG-FREE, R/A, 5WAY, 1M 2MT3013-W05300 CABLE ASSY, PLUG-FREE, R/A, 8WAY, 1M 2MT3013-W08200 Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1
2MT3012-W03300 价格&库存
很抱歉,暂时无法提供与“2MT3012-W03300”相匹配的价格&库存,您可以联系我们找货
