Bipolar Transistor
Collector
3
2
Base
1
Emitter
Description:
A silicon epitaxial PNP planar transistor in a TO-39 type package designed for use as drivers for high power transistors in
general purpose amplifier and switching circuits.
Maximum Ratings:
Characteristic
Collector - Emitter Voltage
Collector - Base Voltage
Emitter - Base Voltage
Collector Current
Base Current
Total Device Dissipation (TC = +25°C)
Total Device Dissipation(TA = +25°C)
Symbol
VCEO
IE
IC
IB
Ptot
Rating
60
V
7
1
A
200
mA
6
1
Operating Junction Temperature
TJ
+200
Storage Temperature Range
Tstg
-65 to +200
RthJC
29
Thermal Resistance, Junction-to-Case
Unit
W
°C
°C/W
www.element14.com
www.farnell.com
www.newark.com
Page
23/04/13
V1.0
Bipolar Transistor
Electrical Characteristics: (TA = +25°C Unless otherwise specified)
Parameter
Collector Cutoff Current
Symbol
Test Conditions
ICBO
VCB = 60V, IE = 0
100
µA
ICEO
VCE = 40V, IB = 0
1
mA
100
µA
ICEV
Min
VCE = 60V, VBE = -1.5V
Max
Unit
VCE = 40V, VBE = -1.5V, TC = +150°C
1
mA
IEBO
VEB = 4V, lC = 0
500
µA
Collector - Emitter Sustaining Voltage
VCEO(sus)
lC = 100mA, IB = 0, (Note1)
Collector - Emitter Saturation Voltage
Emitter Cutoff Voltage
VCE(sat)
lC = 1A, IB = 125mA, (Note1)
Base-Emitter On Voltage
VBE
VCE = 1V, lC = 250mA
DC Current Gain
hFE
Transition Frequency
ft
Collector - Base Capactiance
Small - Signal Current Gain
60
0.6
lC = 250mA, VCE = 1V, (Note 1)
30
lC = 1A, VCE = 1V, (Note 1)
10
VCE = 10V, lC = 100mA, f = 1MHz
3
V
1
150
MHz
Ccbo
VCB = 10V, lE = 0, f = 0.1MHz
100
pF
hfe
VCE = 10V, lC = 50mA, f = 1kHz
25
Note:
1. Pulse Test : Pulse Width %300µs, Duty Cycle %1%
Dimensions
A
B
C
D
E
F
G
H
I
J
K
Min.
8.5
7.74
6.09
0.4
2.41
4.82
0.71
0.73
12.7
42°
Max.
9.39
8.5
6.6
0.53
0.88
2.66
5.33
0.86
1.02
48°
Dimensions : Millimetres
Pin Configuration:
1. Emitter
2. Base
3. Collector
Part Number Table
Description
Part Number
Transistor, PNP, 1A, 60V, TO-39
2N4235
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012.
www.element14.com
www.farnell.com
www.newark.com
Page
23/04/13
V1.0
很抱歉,暂时无法提供与“2N4235”相匹配的价格&库存,您可以联系我们找货
