CH25-2032LF
CH25-2032LF
    MULTICOMP
    插件
    电池座 插件
CH25-2032LF 数据手册
REVISIONS PART NO. CH25-2032LF ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE - A RELEASED Asha 26/11/11 Veena 26/11/11 APPRVD DATE 10/12/11 Section A-A PCB Mounting Layout Specifications: Dimensions : Millimetres General Tolerance Material: Housing Contact Current rating Voltage rating Contact resistance Insulation resistance Temperature range Humidity : PBT black colour : Phosphor bronze 0.6 thick Tin plated over nickel : 3 A ac / dc : 500 V ac / dc : 12 mΩ : 500 MΩ : -40°C to +105°C : 40°C and 90 - 95% RH for 96 hrs Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. Dimension : 0 ±0.3 0 ±0.2 Angle : ±3° 0 ±0.1 Part Number Table Description Part Number Battery Holder, DIP, 20 mm CH25-2032LF www.element14.com www.farnell.com www.newark.com DRAWN BY: Asha CHECKED BY: DATE: 26/11/11 DATE: Veena 26/11/11 APPROVED BY: DATE: 10/12/11 DRAWING TITLE: Battery Holder SIZE A DWG NO. SCALE: NTS M10002768 U.O.M.: mm REV ELECTRONIC FILE CH 25-2032LF_DWG SHEET: 1 OF A 1
CH25-2032LF 价格&库存
很抱歉,暂时无法提供与“CH25-2032LF”相匹配的价格&库存,您可以联系我们找货
