2CM3024-W07300
2CM3024-W07300
    MULTICOMP
2CM3024-W07300 数据手册
Waterproof Circular Connectors Panel, Male, Solder Type - 2A Dimensions : Millmetres Panel, Male, Solder Type - 5A Dimensions : Millmetres Panel, Male, Solder Type - 10A Dimensions : Millmetres Connector Type Current Rating 2A Contact IP Rating 10 12 4 5 5A 6 7 IP 67 8 2 10A 3 4 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Panel Waterproof Cap Dimensions : Millmetres Connector Type Current Rating Contact IP Rating - - IP67 Panel Dust Cap Dimensions : Millmetres Connector Type Current Rating Contact IP Rating - - IP67 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Female Straight Plug, Molding Type - 2A Dimensions : Millmetres Female Straight Plug, Molding Type - 5A Dimensions : Millmetres Female Straight Plug, Molding Type - 10A Dimensions : Millmetres Connector Type Current Rating 2A Contact IP Rating 10 12 4 5 5A 6 7 IP 67 8 2 10A 3 4 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Female Plug, Assembly Type - 2A Dimensions : Millmetres Male Plug, Assembly Type - 5A Dimensions : Millmetres Male Plug, Assembly Type - 10A Dimensions : Millmetres Connector Type Current Rating 2A Contact IP Rating 10 12 4 5 5A 6 7 IP 67 8 2 10A 3 4 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Male Straight Plug, Molding Type - 5A Dimensions : Millmetres Male Straight Plug, Molding Type - 10A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 4 5 5A 6 7 8 IP67 2 10A 3 4 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Male R/A Plug, Molding Type - 5A Dimensions : Millmetres Male R/A Plug, Molding Type - 10A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 4 5 5A 6 7 8 IP67 2 10A 3 4 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Panel, Male, Solder Type - 10A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 10A 3 IP67 Female Straight Plug, Molding Type - 10A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 10A 3 IP65 Panel, Female, Solder Type - 10A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 10A 3 IP67 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Panel, Male, Solder Type - 5A Dimensions : Millmetres Panel, Male, Solder Type - 16A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 7 5A 8 9 16A IP67 3 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Panel Waterproof Cap Dimensions : Millmetres Connector Type Current Rating Contact IP Rating - - IP67 Panel Dust Cap Dimensions : Millmetres Connector Type Current Rating Contact IP Rating - - IP67 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Female Straight Plug, Molding Type - 5A Dimensions : Millmetres Female Plug, Assembly Type - 16A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 7 5A 8 9 16A IP67 3 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Female Straight Plug, Molding Type - 16A Dimensions : Millmetres Male Straight Plug, Molding Type - 5A Dimensions : Millmetres Connector Type Current Rating Contact IP Rating 7 5A 8 9 16A IP67 3 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Specifications Standard Value Description Panel Mount, Molded with Cable, Assembly Type Current Rating Standard size Middle size : 2A, 5A, 10A : 5A, 10A, 16A Pin Configuration Standard size Middle size : 2 to 8, 10, 12 contacts : 3 to 9 contacts Material Contact Connector Body : Copper Alloy, Gold Plated : Nylon + GF, PBT Temperature Range Cable Connector Body : -20°C to + 80°C : -40°C to 105°C IP Rating IP67 and IP68 Contact Resistance ≤10mΩ Insulation Resistance ≥100MΩ at DC 500V Durability 500 cycles Minimum Breakdown Voltage ≥AC 500V/1 Minute Corrosion 48 Hours Salt Spray Contact Part Number Table Description Part Number PLUG, PANEL, 2A, 10 WAY, IP67 2CT3002-W10200 PLUG, PANEL, 2A, 12 WAY, IP67 2CT3002-W12200 PLUG, PANEL, 5A, 4 WAY, IP67 2CT3002-W04300 PLUG, PANEL, 5A, 5 WAY, IP67 2CT3002-W05300 PLUG, PANEL, 5A, 6 WAY, IP67 2CT3002-W06300 PLUG, PANEL, 5A, 7 WAY, IP67 2CT3002-W07300 PLUG, PANEL, 5A, 8 WAY, IP67 2CT3002-W08300 PLUG, PANEL, 10A, 2 WAY, IP67 2CT3002-W02400 PLUG, PANEL, 10A, 3 WAY, IP67 2CT3002-W03400 PLUG, PANEL, 10A, 4 WAY, IP67 2CT3002-W04400 DUST CAP, FOR PANEL PLUG, SCREW 2CT3000-W0000W DUST CAP, FOR PANEL PLUG, SNAP-IN 2CT3000-W0000D CABLE ASSY, SKT-FREE END, 10WAY, 1M 2CT3004-W10200 CABLE ASSY, SKT-FREE END, 12WAY, 1M 2CT3004-W12200 CABLE ASSY, SKT-FREE END, 4WAY, 1M 2CT3004-W04300 CABLE ASSY, SKT-FREE END, 5WAY, 1M 2CT3004-W05300 CABLE ASSY, SKT-FREE END, 6WAY, 1M 2CT3004-W06300 CABLE ASSY, SKT-FREE END, 7WAY, 1M 2CT3004-W07300 CABLE ASSY, SKT-FREE END, 8WAY, 1M 2CT3004-W08300 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Part Number Table Description Part Number CABLE ASSY, SKT-FREE END, 2WAY, 1M 2CT3004-W02400 CABLE ASSY, SKT-FREE END, 3WAY, 1M 2CT3004-W03400 CABLE ASSY, SKT-FREE END, 4WAY, 1M 2CT3004-W04400 CABLE ASSY, SKT-FREE, R/A,10WAY, 1M 2CT3010-W10200 CABLE ASSY, SKT-FREE, R/A,12WAY, 1M 2CT3010-W12200 CABLE ASSY, SKT-FREE, R/A,4WAY, 1M 2CT3010-W04300 CABLE ASSY, SKT-FREE, R/A,5WAY, 1M 2CT3010-W05300 CABLE ASSY, SKT-FREE, R/A,6WAY, 1M 2CT3010-W06300 CABLE ASSY, SKT-FREE, R/A,7WAY, 1M 2CT3010-W07300 CABLE ASSY, SKT-FREE, R/A,8WAY, 1M 2CT3010-W08300 CABLE ASSY, SKT-FREE, R/A,2WAY, 1M 2CT3010-W02400 CABLE ASSY, SKT-FREE, R/A,3WAY, 1M 2CT3010-W03400 CABLE ASSY, SKT-FREE, R/A,4WAY, 1M 2CT3010-W04400 CABLE ASSY, PLUG-FREE END, 4WAY, 1M 2CT3024-W04300 CABLE ASSY, PLUG-FREE END, 5WAY, 1M 2CT3024-W05300 CABLE ASSY, PLUG-FREE END, 6WAY, 1M 2CT3024-W06300 CABLE ASSY, PLUG-FREE END, 7WAY, 1M 2CT3024-W07300 CABLE ASSY, PLUG-FREE END, 8WAY, 1M 2CT3024-W08300 CABLE ASSY, PLUG-FREE END, 2WAY, 1M 2CT3024-W02400 CABLE ASSY, PLUG-FREE END, 3WAY, 1M 2CT3024-W03400 CABLE ASSY, PLUG-FREE END, 4WAY, 1M 2CT3024-W04400 CABLE ASSY, PLUG-FREE, R/A, 4WAY, 1M 2CT3028-W04300 CABLE ASSY, PLUG-FREE, R/A, 5WAY, 1M 2CT3028-W05300 CABLE ASSY, PLUG-FREE, R/A, 6WAY, 1M 2CT3028-W06300 CABLE ASSY, PLUG-FREE, R/A, 7WAY, 1M 2CT3028-W07300 CABLE ASSY, PLUG-FREE, R/A, 8WAY, 1M 2CT3028-W08300 CABLE ASSY, PLUG-FREE, R/A, 2WAY, 1M 2CT3028-W02400 CABLE ASSY, PLUG-FREE, R/A, 3WAY, 1M 2CT3028-W03400 CABLE ASSY, PLUG-FREE, R/A, 4WAY, 1M 2CT3028-W04400 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1 Waterproof Circular Connectors Part Number Table Description Part Number SOCKET, PANEL, 10A, 3 WAY, IP67 2CT3014-W03400 SOCKET, SQ. PANEL, 10A, 3 WAY, IP55 2CT3020-W034A1 CABLE ASSY, PLUG-FREE END, 3WAY, 1M 2CT3016-W03402 PLUG, PANEL, 5A, 7 WAY, IP67 2CM3002-W07300 PLUG, PANEL, 5A, 8 WAY, IP67 2CM3002-W08300 PLUG, PANEL, 5A, 9 WAY, IP67 2CM3002-W09300 PLUG, PANEL, 16A, 3 WAY, IP67 2CM3002-W03600 DUST CAP, FOR PANEL PLUG, SCREW 2CM3000-W0000W DUST CAP, FOR PANEL PLUG, SNAP-IN 2CM3000-W0000D CABLE ASSY, SKT-FREE END, 7WAY, 1M 2CM3004-W07300 CABLE ASSY, SKT-FREE END, 8WAY, 1M 2CM3004-W08300 CABLE ASSY, SKT-FREE END, 9WAY, 1M 2CM3004-W09300 CABLE ASSY, SKT-FREE END, 3WAY, 1M 2CM3004-W03600 CABLE ASSY, PLUG-FREE END, 3WAY, 1M 2CM3016-W03601 CABLE ASSY, PLUG-FREE END, 7WAY, 1M 2CM3024-W07300 CABLE ASSY, PLUG-FREE END, 8WAY, 1M 2CM3024-W08300 CABLE ASSY, PLUG-FREE END, 9WAY, 1M 2CM3024-W09300 Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 01/02/11 V1.1
2CM3024-W07300 价格&库存
很抱歉,暂时无法提供与“2CM3024-W07300”相匹配的价格&库存,您可以联系我们找货
