Type HS10 Solder Wire
Description
The electronic solder wire HS10 is a proven and reliable product of research, which was
developed to meet high quality requirements in industrial electronic production as well as for
quick rework. The solder wire HS10 is very efficient by its high activity, which results in quick
spread of solder and electrical safe residues. It is a halide activated rosin (colophony) flux.
The solder wire HS10 according to J-STD-004 type ROM1.
Applications
The solder wire HS10 can be used for hand and robot soldering in electronics and electrical assembly, audio devices and
telecommunication. Flux residues can remain on surfaces without cleaning.
Features
• Solid and dry residues, pin testable
• Fast soldering, high spread speed
• High reliability
Physical Properties and Data
General Properties
HS10
Flux Type
ROM1 / J-STD-004
Flux Content
standard 2.5 weight % ± 0.3 %
Halide Content
0.9%
Corrosion Effect
None / J-STD-004
Standard alloys
acc. to ISO 9453:2014
Lead-containing:
Lead-free (Ecoloy Serie)
S-Sn60Pb40
Ecoloy TS (S-Sn96.3Ag3.7)
S-Sn60Pb39Cu1
Ecoloy TSC (S-Sn95.5Ag3.8Cu0.7)
S-Pb60Sn40
Ecoloy TC (S-Sn99.3Cu0.7)
S-Sn62Pb36Ag2
Ecoloy TSC305 (S-Sn96Ag3Cu0.5)
S-Sn63Pb37*
S-Pb93Sn5Ag2
Available Diameters
from 0.3mm
Available Reel Sizes
250g
* This alloy is subject to a MOQ
Newark.com/exclusive-brands
Farnell.com/exclusive-brands
Element14.com/exclusive-brands
Page
25/08/21
V1.0
Part Number Table
Description
Part Number
Solder Wire, Lead Free, 0.5mm, 250g
595000
507-1290
Solder Wire, Lead Free, 0.7mm, 250g
595001
595021
Solder Wire, Lead Free, 0.7mm, 500g
595024
Solder Wire, Lead Free, 0.9mm, 250g
507-1318
Solder Wire, Lead Free, 0.9mm, 500g
507-1355
Solder Wire, Lead Free, 1.2mm, 250g
595003
507-1320
Solder Wire, Lead Free, 1.2mm, 500g
507-1367
Solder Wire, Lead Free, 1mm, 250g
595002
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for
the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness,
any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make
any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or
where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its
negligence. Multicomp is the registered trademark of Premier Farnell Limited 2019.
Page
25/08/21
V1.0
很抱歉,暂时无法提供与“507-1355”相匹配的价格&库存,您可以联系我们找货
