DB25-PD
DB25-PD
    MULTICOMP
DB25-PD 数据手册
D Sub Housing, Standard, 25Pos, Plug Specifications: Material: Standard insulator Optional Hi-Temp insulator Insulator colour Contacts Shell Hardware : PBT, 30% glass reinforced : Nylon 6T : Black : Phosphor Bronze : Steel, Tin or Zinc plated : Brass, Nickel plated Contact Plating: Gold Flash (15 and 30 μin Optional) over Nickel underplate on mating area. Tin over copper underplate on PCB tails. Electrical: Operating voltage Current rating Contact resistance Insulation resistance Dielectric withstanding voltage : 250V AC / DC Max. : 5A Max. : 20MΩ Max. initial : 5,000MΩ Min. : 1,000V AC for 1 Minute Mechanical: Insertion force Extraction force : 0.75 lbs Max. : 0.44 lbs Min Temperature Rating: Operating temperature : -65°C to +125°C Soldering process temperature: Standard insulator Hi-Temp insulator : 235°C : 260°C www.element14.com www.farnell.com www.newark.com Page 07/07/14 V1.0 D Sub Housing, Standard, 25Pos, Plug Dimensions : Inch (Millimetres) Part Number Table Description Part Number D Sub Housing, Standard, 25Pos, Plug DB25-PD Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 07/07/14 V1.0
DB25-PD 价格&库存
很抱歉,暂时无法提供与“DB25-PD”相匹配的价格&库存,您可以联系我们找货
