DH-023L2F
DH-023L2F
    MULTICOMP
    MULTICOMP - DH-023L2F - D Sub Screwlock / Slidelock, 1.9mm Nut, 14.5 mm, 4-40 UNC
DH-023L2F 数据手册
REVISIONS PART NO. DH-023-2.85 ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED DO 04/05/12 ER 04/05/12 ER 04/05/12 Screw: 2pcs Material: Brass, Nickel–Plated Nut: 2pcs Material: Steel, Nickel–Plated Flat Washer: 2pcs Material: Steel, Nickel–Plated Split Washer: 2pcs Material: Steel, Nickel–Plated www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: DO UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 04/05/12 DRAWING TITLE: Screwlock, 4-40UNC DATE: SIZE 04/05/12 A4 DATE: 04/05/12 DWG NO. ELECTRONIC FILE DH-023-2.85-01 SCALE: NTS REV DH-023-2.85-1 U.O.M.: mm (inch) SHEET: 1 of 4 1.1 REVISIONS PART NO. DH-023-2.85 ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED DO 04/05/12 ER 04/05/12 ER 04/05/12 Screw: 2pcs Material: Brass, Nickel–Plated Nut: 2pcs Material: Steel, Nickel–Plated Flat Washer: 2pcs Material: Steel, Nickel–Plated Split Washer: 2pcs Material: Steel, Nickel–Plated www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: DO UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 04/05/12 DRAWING TITLE: Screwlock, 4-40UNC DATE: SIZE 04/05/12 A4 DATE: 04/05/12 DWG NO. ELECTRONIC FILE DH-023-2.85-01 SCALE: NTS REV DH-023-2.85-1 U.O.M.: mm (inch) SHEET: 2 of 4 1.1 REVISIONS PART NO. DH-023-2.85 ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED DO 04/05/12 ER 04/05/12 ER 04/05/12 Screw: 2pcs Material: Brass, Nickel–Plated Nut: 2pcs Material: Steel, Nickel–Plated Flat Washer: 4pcs Material: Steel, Nickel–Plated Split Washer: 2pcs Material: Steel, Nickel–Plated www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: DO UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 04/05/12 DRAWING TITLE: Screwlock, 4-40UNC DATE: SIZE 04/05/12 A4 DATE: 04/05/12 DWG NO. ELECTRONIC FILE DH-023-2.85-01 SCALE: NTS REV DH-023-2.85-1 U.O.M.: mm (inch) SHEET: 3 of 4 1.1 REVISIONS PART NO. DH-023-2.85 ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED DO 04/05/12 ER 04/05/12 ER 04/05/12 Screw: 2pcs Material: Brass, Nickel–Plated Nut: 2pcs Material: Steel, Nickel–Plated Part Number Table Flat Washer: 4pcs Material: Steel, Nickel–Plated Split Washer: 2pcs Material: Steel, Nickel–Plated Description Part Number Screwlock, 12.7mm 4-40UNC 2.85mm Nut DH-023-2.85 Screwlock, 12.7mm 4-40UNC 1.9mm Nut DH-023 Screwlock, 19.3mm 4-40UNC 2.85mm Nut DH-023L2F-2.85 Screwlock, 19.3mm 4-40UNC 1.9mm Nut DH-023L2F www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: DO UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 04/05/12 DRAWING TITLE: Screwlock, 4-40UNC DATE: SIZE 04/05/12 A4 DATE: 04/05/12 DWG NO. ELECTRONIC FILE DH-023-2.85-01 SCALE: NTS REV DH-023-2.85-1 U.O.M.: mm (inch) SHEET: 4 of 4 1.1
DH-023L2F 价格&库存
很抱歉,暂时无法提供与“DH-023L2F”相匹配的价格&库存,您可以联系我们找货
DH-023L2F
  • 5+8.89875
  • 10+7.67666
  • 25+6.79865
  • 50+5.73080
  • 100+5.42231
库存:19177
