HER106G
HER106G
    MULTICOMP
HER106G 数据手册
Diode Fast Features: •  •  •  •  •  •  Glass passivated chip junction High efficiency, low VF High current capability High reliability High surge current capability For use in low voltage, high frequency inventor, free wheeling, and polarity protection application Specifications: Mechanical Data: Cases : Moulded plastic DO-41 Lead : Pure tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed Polarity : Colour band denotes cathode end High temperature soldering guaranteed : 260°C/10 seconds/0.375ʺ, (9.5mm) lead lengths at 5lbs., (2.3kg) tension Weight : 0.34g Maximum Ratings and Electrical Characteristics: Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol HER102G HER104G HER106G HER108G Maximum Recurrent Peak Reverse Voltage Vrrm 100 300 600 1,000 Maximum RMS Voltage Vrms 70 210 420 700 Maximum DC Blocking Voltage Vdc 100 300 600 1,000 Maximum Average Forward Rectified Current 0.375ʺ (9.5mm) Lead Length at Ta = 55°C I(av) Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method ) Ifsm Maximum Instantaneous Forward Voltage at 1A Units V 1 A Vf 30 1 1.7 V www.element14.com www.farnell.com www.newark.com Page 08/02/13 V1.0 Diode Fast Type Number Symbol HER102G HER104G HER106G HER108G Units Maximum DC Reverse Current at Ta = 25°C at Rated DC Blocking Voltage at Ta = 125°C Ir Maximum Reverse Recovery Time (Note 1) Trr 50 75 nS Typical Junction Capacitance (Note 2) Cj 15 10 pF Typical Thermal Resistance Operating Temperature Range Storage Temperature Range 5 150 RθJA RθJC Tj Tstg μA μA 70 15 °C/W -65 to +150 °C Note: 1. Reverse Recovery Test Conditions: IF = 0.5A, IR = 1A, IRR = 0.25A. Note: 2. Measured at 1MHz and Applied Reverse Voltage of 4V DC. Note: 3. Mount on Cu-Pad Size 5mm × 5mm on PCB. Ratings and Characteristic Curves (HER102G, HER104G, HER106G, HER108G) www.element14.com www.farnell.com www.newark.com Page 08/02/13 V1.0 Diode Fast www.element14.com www.farnell.com www.newark.com Page 08/02/13 V1.0 Diode Fast Note: 1. Rise Time = 7ns Maximum Input Impedance = 1MΩ 22pf Note: 2. Rise Time = 10ns Maximum Source Impedance = 50Ω Part Number Table Dimensions : Inches (Millimetres) Description Part Number Diode, Fast, 1A, 100V HER102G Diode, Fast, 1A, 300V HER104G Diode, Fast, 1A, 600V HER106G Diode, Fast, 1A, 1,000V HER108G Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 08/02/13 V1.0
HER106G
物料型号包括HER102G、HER104G、HER106G和HER108G。
器件简介为快速二极管,符合RoHS标准,具有玻璃钝化芯片结、高效率、低正向电压、高电流能力、高可靠性、高浪涌电流能力等特点。
引脚分配为色环端表示阴极。
参数特性包括最大重复峰值反向电压、最大RMS电压、最大直流阻断电压、最大平均正向整流电流、峰值正向浪涌电流、最大瞬时正向电压、最大反向电流、最大反向恢复时间、典型结电容和典型热阻。
功能详解为低电压、高频整流、自由轮转和极性保护应用。
应用信息为可在低电压、高频整流、自由轮转和极性保护应用中使用。
封装信息为模塑塑料DO-41封装,纯锡镀层,无铅,符合MIL-STD-202标准,260°C/10秒/0.375英寸(9.5mm)引脚长度在5磅(2.3kg)张力下保证高温焊接。
HER106G 价格&库存
很抱歉,暂时无法提供与“HER106G”相匹配的价格&库存,您可以联系我们找货
