3151-81-02A
3151-81-02A
    MULTICOMP
3151-81-02A 数据手册
Panel Mount Neon Indicator Features: •  T  he neon indicator is rear panel mounting and snaps into the lens making a simple and secure mounting. An appropriate resistor is incorporated in the body moulding. •  Termination 200mm PVC flexible leads. •  Quick, simple assembly operation. •  Lens snaps through panel onto indicator. Technical Data: Terminal Type Flammability Resistance to tracking Panel cut-out    Panel Thickness    Cutout size Material    Base    Lens Lead wire Voltage Rating Life : Leaded : UL 94V-2 minimum : PTI 250 : 0.7mm to 1mm : 9.5mm × 4.6mm : Nylon 6/6 : Polycarbonate : 22 AWG : 110V AC to 125V AC 0.3W 240V AC to 250V AC, 0.3W : ≥30,000 hours Specification Table Part Number Length Depth (Excluding Leads) Behind Panel Lens Diameter 3151-81-02A 31 9 2.5 × 12 3151-81-03A 30 9.2 2.3 3151-82-05A 31 9 2.5 × 12 Panel Cut-Out Diameter Max. Panel Thickness Colour 9.5 2 Amber Red Green Dimensions : Millimetres Dimensions Bezel Types Dimensions : Millimetres www.element14.com www.farnell.com www.newark.com Page 16/06/17 V1.0 Panel Mount Neon Indicator 31 5 200 Dimensions : Millimetres Part Number Table Description Neon Indicator - Rear Panel Mounting Colour Part Number Red 3151-81-02A Amber 3151-81-03A Green 3151-82-05A Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com Page 16/06/17 V1.0
3151-81-02A 价格&库存
很抱歉,暂时无法提供与“3151-81-02A”相匹配的价格&库存,您可以联系我们找货
