507-1227
507-1227
    MULTICOMP
507-1227 数据手册
60/40 Mildly Activated No-Clean Flux Solder Wire Features: •  •  •  •  •  Halide free version-Multicomp 400 Fast soldering-range of activities to suit all applications Good spread on copper, brass and nickel Clear residues Heat stable-low spitting Product Range: Multicomp 400 is designed for users who require a halide free formulation. The remaining products in the range contain higher halide levels to maximise soldering power. Multicomp 400, 502, 505 and 511 cored wires are manufactured with a range of flux contents. Although users will normally be using products with a nominal flux content of 3%, the superior performance of the these products may allow a lower flux content to be specified e.g 2.2%. This will further improve residue appearance by reducing the quantity. For applications requiring low residue halide free fluxes, Multicomp 400 is available at 1% flux content (formerly Multicomp X-39). Multicomp 400, 502, 505 and 511 cored wires are available in a variety of alloys conforming to J-STD-006 and EN 29453 or alloys conforming to similar national or international standards. Technical Specification: Alloys: The alloys used for Multicomp cored solder wires conform to the purity requirements of the common national and international standards. A wide range of wire diameters is available manufactured to close dimensional tolerances. Flux: Multicomp 400, 502, 505 and 511 solid fluxes are based on modified rosins and carefully selected activators. In use they exhibit a mild rosin odour and leave a small quantity of clear residue. Flux Properties Test Acid value, mg/KOH/g 400 502 505 511 205 - 220 156 - 172 159 - 177 164 - 176 Halide content, % 0 0.2 0.5 1.1 J-STD-004 solder spread mm2 corrosion test 210 Pass 310 Pass 315 Pass 340 Pass 1.2.2 ROM1 MR3CN 1.1.2 ROM1 MR3CN SIR test (without cleaning) IPC-SF-818 Class3 Bellcore TR-NWT-000078 Pass Pass Electromigration-test (without cleaning) Bellcore TR-NWT-000078 Classification EN 29454-1 J-STD-004 IPC-SF-818 Pass 1.1.3 ROLO LR3CN 1.1.2 ROM1 MR3CN www.element14.com www.farnell.com www.newark.com Page 26/03/13 V1.0 60/40 Mildly Activated No-Clean Flux Solder Wire Special Properties: Multicomp 400, 502, 505 and 511 cored solder wires are designed to give fast and sustained wetting on both copper and brass. This can be demonstrated using spreading tests on both substrates under standard conditions for the Multicomp products and comparable competitor products. After 5 seconds, area of spread is measured to form a comparative index indicating total flux efficacy. Relative Wetting Performance of Multicomp and Halide Free Competitor Products* Area of Spread (mm2) Flux Content (%) Product Oxidised Copper* Oxidised Brass 209 Multicomp 400 2.2 222 Competitor A 3.5 191 Competitor B 2.5 202 140 *Oxidised for 1 hour at 205°C Relative Wetting Performance of Multicomp and Competitor Products* Area of Spread (mm2) Flux Content (%) Halide Content (%) Oxidised Copper* Oxidised Brass Multicomp 502 2.7 0.2 220 160 Competitor E 2.0 200 150 Competitor F 2.4 190 180 Competitor G 3.5 150 120 230 150 220 240 Product Competitor H Multicomp 505 2.7 0.4 0.5 *Oxidised for 1 hour at 205°C Recommended Operating Conditions: Soldering Iron: Good results should be obtained using a range of tip temperatures. However, the optimum tip temperature and heat capacity required for a hand soldering process is a function of both soldering iron design and the nature of the task and care should be exercised to avoid unnecessarily high tip temperatures for excessive times. A high tip temperature will increase any tendency to flux spitting and it may produce some residue darkening. The soldering iron tip should be properly tinned and this may be achieved using Multicomp cored wire. Severely contaminated soldering iron tips should first be cleaned and pre-tinned using Multicomp Tip Tinner/Cleaner TTC1, then wiped on a clean, damp sponge before re-tinning with Multicomp cored wire. Soldering process: Multicomp cored wires contain a careful balance of resins and activators to provide clear residues, maximum activity and high residue reliability, without cleaning in most situations. To achieve the best results from Multicomp solder wires, recommended working practices for hand soldering should be observed as follows: •  A  pply the soldering iron tip to the work surface, ensuring that it simultaneously contacts the base material and the component termination to heat both surfaces adequately. This process should only take a fraction of a second. •  Apply Multicomp flux cored solder wire to a part of the joint surface away from the soldering iron and allow to flow sufficiently to form a sound joint fillet – this should be virtually instantaneous. Do not apply excessive solder or heat to the joint as this may result in dull, gritty fillets and excessive or darkened flux residues. •  Remove solder wire from the work piece and then remove the iron tip. www.element14.com www.farnell.com www.newark.com Page 26/03/13 V1.0 60/40 Mildly Activated No-Clean Flux Solder Wire The total process will be very rapid, depending upon thermal mass, tip temperature and configuration and the solderability of the surfaces to be joined. Multicomp flux cored solder wires provide fast soldering on copper and brass surfaces as well as solder coated materials. Activity of the halide activated versions on nickel is also good depending on the state of oxidation of the nickel finish. The good thermal stability of Multicomp fluxes means they are also well suited to soldering applications requiring high melting temperature alloys. Cleaning: Multicomp 400, 502, 505 and 511flux cored solder wires have been formulated to leave pale flux residues and to resist spilling and fuming. Cleaning will not be required in most situations but if necessary this is best achieved using Multicomp MCF800 Cleaner. Other proprietary solvent or semi-aqueous processes may be suitable. Saponification may be viable but customers must ensure that the desired level of cleanliness can be achieved by their chosen system. Healthy and Safety: Warning: The following information is for guidance only and users must refer to the Material Safety Data Sheets relevant to specific Multicomp flux cored solder wires before use. Health Hazards and Precautions: Inhalation of the flux fumes given off during soldering should be avoided. The fumes are irritating to the throat and respiratory system. Prolonged or repeated exposure to rosin or modified rosin based flux fumes may lead to the development of respiratory sensitisation and occupational asthma. Multicomp solder wires must always be used with suitable fume extraction equipment to remove fumes from the breathing zone of operators and the general work environment. Solder alloys containing lead give off negligible fume at normal soldering temperatures up to 500°C. Normal handling of lead alloy wires will not cause lead to be absorbed through the skin. The most likely route of entry is through ingestion but this will not be significant if a good standard of personal hygiene is maintained. Eating, drinking and smoking should not be permitted in the working area. Hands should be washed with soap and warm water after handling solder wire. Waste disposal: Wherever possible, waste solder wire should be recycled for recovery of metal. Otherwise it should be disposed of according to local or national regulations. Part Number Table Description Part Number Solder Wire, 60/40 No-Clean, 0.5mm, 180°, 250g 507-1215 Solder Wire, 60/40 No-Clean, 0.7mm, 250g 507-1227 Solder Wire, 60/40 No-Clean, 0.9mm, 250g 507-1239 Solder Wire, 60/40 No-Clean, 1.2mm, 250g 507-1240 Solder Wire, 60/40 No-Clean, 0.7mm, 500g 507-1264 Solder Wire, 60/40 No-Clean, 0.9mm, 500g 507-1276 Solder Wire, 60/40 No-Clean, 1.2mm, 500g 507-1288 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 26/03/13 V1.0
507-1227 价格&库存
很抱歉,暂时无法提供与“507-1227”相匹配的价格&库存,您可以联系我们找货
