Locking Fork
Vinyl Insulated, Butted Seam
Specifications:
Barrel Seam
Max. Voltage Rating
: Butted
: 600V Building Wire
1,000V Signs, Fixtures and Luminaires
: 221°F (105°C)
: Same as Wire
: Vinyl
: ETP Copper
: Tin
Max. Temperature Rating
Max. Current
Insulator Material
Terminal Material
Plating
W
C
L
E
Stud
Size
Max.
Lock
Width
W
6
0.27
0.25
8
0.34
0.30
CLS-TV-1810
10
0.35
0.32
CLS-TV-1406
6
0.27
0.25
8
0.34
0.30
CLS-TV-1410
10
0.35
0.32
CLS-TV-1006
6
0.30
0.28
8
0.35
10
0.36
1/4
0.48
Part Number
Wire
Range
(AWG)
CLS-TV-1806
CLS-TV-1808
CLS-TV-1408
CLS-TV-1008
CLS-TV-1010
22-18
16-14
12-10
CLS-TV-1025
0.32
0.43
C
0.25
L
0.88
E
0.7
Thickness
Barrel
Length
0.44
1.03
1.24
0.83
Max.
Insulation
Diameter
0.07
0.145
0.03
0.25
0.28
Barrel
I.D.
0.04
0.09
0.135
0.17
0.25
0.99
Dimensions : Inches
www.element14.com
www.farnell.com
www.newark.com
Page
24/10/13
V1.0
Locking Fork
Engineering Specification:
Crimp-type terminals shall, electrically and mechanically, connect to a pre-stripped end of a stranded copper wire and have a
flat tongue portion with a central opening for mounting around a screw or stud.
The terminal line shall offer tongue variations in hole (stud) size (6, 8 10, etc.) and configuration (ring, fork, block fork, flanged
block fork, locking fork, etc.) and barrel variations in wire (AWG) size (22-18, 16-14, 12-10, etc.) and construction (non-insulated
brazed seam, vinyl insulated butted seam, nylon insulated with insulation grip, etc.). The terminal tongue shall be marked with
the wire range and manufacturer’s symbol ( ).
The vinyl-insulated, butted seam locking fork terminal shall be tin-plated, annealed copper, with the tongue having a specified
stud slot (size 4 thru 1/4 in.) and a butted seam barrel covered by a molded vinyl funnel entry sleeve, colour coded and sized,
for a specified (AWG) wire range (22-18, 16-14, 12-10).
Part Number Table
Description
Part Number
CLS-TV-1806
CLS-TV-1808
CLS-TV-1810
CLS-TV-1406
Locking Fork, Vinyl Insulated, Butted Seam
CLS-TV-1408
CLS-TV-1410
CLS-TV-1006
CLS-TV-1008
CLS-TV-1010
CLS-TV-1025
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012.
www.element14.com
www.farnell.com
www.newark.com
Page
24/10/13
V1.0
很抱歉,暂时无法提供与“CLS-TV-1806”相匹配的价格&库存,您可以联系我们找货
