EBV-02-D
EBV-02-D
    MULTICOMP
EBV-02-D 数据手册
REVISIONS PART NO. ECN # REV DESCRIPTION - A RELEASED EBV-02-D DRAWN DATE Shashi 21/10/11 CHECKD DATE Veena 21/10/11 APPRVD DATE 04/11/11 Specifications: Material: Insulator Insulator colour Contact Wire cage Screw : : : : : PA66 Green Copper alloy, tin plated Steel, M2.5 / Zn plated Steel, M2.5 / Zn plated : : : : 300 V ac 20 Amperes 500 M ohms at 500 V dc 2,000 V ac for 1 minute Electrical: Recommended PCB Layout Operation Voltage Current rating Insulation resistance Dielectric withstanding voltage Mechanical: Wire range (mm2) Torque (N*m) : 0.5 to 2.5 : 0.4 Temperature Rating: Operating temperature : -40°C to 105°C Environmental: Lead free Recommended soldering temperature Dimensions : Inches (Millimetres) : 235°C for 5 s Positions : 2 thru 24 A = 0.2 (5.08) × Number of Positions B = 0.2 (5.08) × Number of Spaces Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. DRAWN BY: Shashi CHECKED BY: DATE: 21/10/11 DATE: Veena 21/10/11 APPROVED BY: DATE: 04/11/11 DRAWING TITLE: Terminal Block, 5.08 mm Pitch SIZE A DWG NO. SCALE: NTS M10002741 U.O.M.: Inches (mm) REV ELECTRONIC FILE A EBV-XX-D_DWG SHEET: 1 OF 2 REVISIONS PART NO. EBV-02-D ECN # REV DESCRIPTION - A RELEASED DRAWN DATE Shashi 21/10/11 CHECKD DATE Veena 21/10/11 APPRVD DATE 04/11/11 Unless Otherwise Specified All Dimensions are Inches (mm) Tolerances: Except as Noted Inches Holes .X ±0.1 Ø.X ±0.1 .XX ±0.2 Ø.XX ±0.15 .XXX ±0.15 Ø.XXX ±0.1 Part Number Table Description Part Number Terminal Block, 5.08 mm Pitch EBV-02-D www.element14.com www.farnell.com www.newark.com Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. DRAWN BY: Shashi CHECKED BY: DATE: 21/10/11 DATE: Veena 21/10/11 APPROVED BY: DATE: 04/11/11 DRAWING TITLE: Terminal Block, 5.08 mm Pitch SIZE A DWG NO. SCALE: NTS M10002741 U.O.M.: Inches (mm) REV ELECTRONIC FILE A EBV-XX-D_DWG SHEET: 2 OF 2
EBV-02-D
PDF文档中包含以下信息: 1. 物料型号:型号为XXXX,是用于XXXX的电子元件。
2. 器件简介:该器件是一种XXXX,具有XXXX的特点。
3. 引脚分配:共有XXXX引脚,各引脚功能如下:引脚1-功能,引脚2-功能,...。
4. 参数特性:工作电压范围为XXXX,工作频率为XXXX,功耗为XXXX。
5. 功能详解:器件的主要功能包括XXXX,XXXX,XXXX。
6. 应用信息:适用于XXXX,XXXX,XXXX等领域。
7. 封装信息:采用XXXX封装,尺寸为XXXX,重量为XXXX。
EBV-02-D 价格&库存
很抱歉,暂时无法提供与“EBV-02-D”相匹配的价格&库存,您可以联系我们找货
