GBPC2508
GBPC2508
    MULTICOMP
    Module
GBPC2508 数据手册
Bridge Rectifier Features: •  T  he glass passivation process offers improvements to reliability at high operating temperatures, moisture resistance capability and overall durability •  Integrally moulded heatsink provided very low thermal resistance for maximum heat dissipation •  Surge overload rating from 300 amperes to 400A •  Terminals solderable per MIL-STD-202, Method 208 (For wire type) •  Isolated voltage from case to lead over 2,500V Note: The maximum values of IO DC quoted are based on the assumption that the device is mounted on a chassis or some form of heatsink. Maximum Ratings and Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number -005 -01 -02 -04 -06 -08 Maximum Recurrent Peak Reverse Voltage 50 100 200 400 600 800 Maximum RMS Voltage 35 70 140 280 420 560 Maximum DC Blocking Voltage 50 100 200 400 600 800 Maximum Average Forward Rectified Current at TC = 55°C GBPC25 GBPC35 25 35 Peak Forward Surge Current, Single Sine-wave Superimposed on Rated Load (JEDEC method ) GBPC25 GBPC35 300 400 Maximum Instantaneous Forward Voltage Drop Per Element at Specified Current GBPC25 GBPC35 12.5A 17.5A Maximum DC Reverse Current at Rated DC Blocking Voltage Per Element Typical Thermal Resistance (Note 1) RθJC Operating and Storage Temperature Range TJ, TSTG Unit V A 1.1 V 5 uA 1.5 °C/W -50 to +150 °C Note: Thermal Resistance from Junction to Case. Dimensions : Millimetres www.element14.com www.farnell.com www.newark.com Page 17/10/12 V1.0 Bridge Rectifier Ratings and Characteristic Curves Maximum Forward Current Derating Curve Maximum Non-Repetitive Forward Surge Current per Bridge Element Typical Reverse Characteristics per Bridge Element Typical Forward Characteristics per Bridge Element www.element14.com www.farnell.com www.newark.com Page 17/10/12 V1.0 Bridge Rectifier Part Number Table Description Bridge Rectifier, 25A, 800V VRRM (V) Maximum Input Voltage (V AC) IO at 55°C (A) 50 35 GBPC25005 100 70 GBPC2501 200 140 400 280 600 420 GBPC2506 800 560 GBPC2508 200 140 600 420 25 35 IFSM (A) 300 400 Part Number GBPC2502 GBPC2504 GBPC3502 GBPC3506 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 17/10/12 V1.0
GBPC2508 价格&库存
很抱歉,暂时无法提供与“GBPC2508”相匹配的价格&库存,您可以联系我们找货
