2CM3024-W03600
2CM3024-W03600
    MULTICOMP
2CM3024-W03600 数据手册
Cable Assembly Plug - Free End Specifications: Waterproof rate : IP67 IP67 : Immersed in 1m water for 30 minutes Cable length tolerance : 1  m to 10m ±5%mm 11m to 99m ±500mm Cable jacket material : Black PVC Specifications : Circular series specifications Dimensions : Millimetres Item Description Material Plating and Colour A Body Nylon + GF Black B Male PIN Brass 6μ Inches Gold Plated Over Nickel Plating C Over Mould PVC Black D Inner Mould TPU Natural www.element14.com www.farnell.com www.newark.com Page 07/09/12 V1.0 Cable Assembly Plug-Free End Part Number Table Description PIN Assignments Front View Cable Specifications Cable Assy, Plug-Free End, 3Way, 1M 16 AWG X 3C + AI/My, (UV Resistant), Outer Diameter = Ø7.0, Wire Colour: 1. Brown, 2. Blue and 3. Black Cable Assy, Plug-Free End, 7Way, 1M 24 AWG X 7C + AI/My, (UV Resistant), Outer Diameter = Ø5.0, Wire Colour: 1. Blue, 2. Black, 3. Yellow, 4. Red,5. Brown, 6. Green and 7. White Cable Assy, Plug-Free End, 8Way, 1M 24 AWG X 8C + AI/My, (UV Resistant), Outer Diameter = Ø5.4, Wire Colour: 1. Black, 2. Brown, 3. White, 4. Blue,5. Red, 6. Grey, 7. Yellow and8. Green Cable Assy, Plug-Free End, 9Way, 1M 24 AWG X 8C + AI/My, (UV Resistant), Outer Diameter = Ø5.4, Wire Colour: 1. Brown, 2. Blue, 3. White, 4. Green, 5. Yellow, 6. Grey, 7. Pink, 8. Red and 9. Black Current Rating Part Number 16A 2CM3024-W03600 2CM3024-W07300 5A 2CM3024-W08300 2CM3024-W09300 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 07/09/12 V1.0
2CM3024-W03600 价格&库存
很抱歉,暂时无法提供与“2CM3024-W03600”相匹配的价格&库存,您可以联系我们找货
