2MT3000-W03300
2MT3000-W03300
    MULTICOMP
2MT3000-W03300 数据手册
M12 Series Rear Mount Female Connector Specifications: Waterproof Rate   IP68 Electrical Characteristics Temperature Range Current Rating Dielectric withstanding Voltage Panell Thickness : IP68 : Immersed in 1m water for 24 hours : -40°C to +100°C : 60V AC/DC : 500V AC for one minute : 3.5mm Max. Diagram Dimensions : Millimetres Item Description Material Plating and Colour A Body Nylon + 33%GF Black Phosphor Bronze Alloy 6μ" Gold Plated Over Nickel Plating B Female PIN C O-Ring Viton Red D Nut Brass Nickel Plating 100μ" E O-Ring EPDM Black F Shield Brass Nickel Plating 100μ" G Liquid Glue - Black www.element14.com www.farnell.com www.newark.com Page 16/11/16 V1.0 M12 Series Rear Mount Female Connector 2MT3000-W03300 2MT3000-W04300 2MT3000-W05300 2MT3000-W08200 Part Number Table Description Current Rating M12 Series Rear Mount Female Connector, 3 Position M12 Series Rear Mount Female Connector, 4 Position 2MT3000-W03300 5A M12 Series Rear Mount Female Connector, 5 Position M12 Series Rear Mount Female Connector, 8 Position Part Number 2MT3000-W04300 2MT3000-W05300 2A 2MT3000-W08200 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 16/11/16 V1.0
2MT3000-W03300 价格&库存
很抱歉,暂时无法提供与“2MT3000-W03300”相匹配的价格&库存,您可以联系我们找货
