EBW-04-B
EBW-04-B
    MULTICOMP
EBW-04-B 数据手册
Vertical PCB Terminal Blocks 3.81mm Pitch Specifications: Material: Insulated Insulator Colour Contact Screw : PA66 : Green : Bronze, Tin Plated : Steel, M2/Zn Plated Electrical: Operation Voltage Current Rating Rated Surge Voltage : 300V AC max. : 12A max per Pole : 1.6/2/3 KV Mechanical: Torque (Lb-in) Solid Wire : 1.73 : 30-16AWG Environmental: Operating Temperature Recommended Soldering Temperature : -40°C to +150°C : 235°C for 5sec. Part Number Table Description Dimensions : Millimetres Terminal Block, Eurostyle, 30-16AWG No. of Part Number Contacts 3 EBW-03-B 4 EBW-04-B 6 EBW-06-B 7 EBW-07-B 8 EBW-08-B 9 EBW-09-B 10 EBW-10-B 12 EBW-12-B Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 24/06/14 V1.0
EBW-04-B 价格&库存
很抱歉,暂时无法提供与“EBW-04-B”相匹配的价格&库存,您可以联系我们找货
