3151-81-05A
3151-81-05A
    MULTICOMP
3151-81-05A 数据手册
REVISIONS PART NO. 3151-81 - Series ECN # REV - A DESCRIPTION RELEASED DRAWN Jagan DATE CHECKD DATE 13/02/10 Sreejesh 13/02/10 APPRVD DATE Farnell 01/03/10 Features: • • • • • • • The neon is rear panel mounting and snaps into the lens making a simple and secure mounting. An appropriate resistor is incorporated in the body moulding. Termination 200mm PVC flexible leads. Quick, simple assembly operation. Lens snaps through panel onto indicator. Won't pull or vibrate off. High brightness neon incorporated. Specifications: Description Voltage Rating Life : Red, amber and green indicator. : 220 to 250V ac. : >30,000 hours for neon lamp 20,000 hours minimum for neon lamp (3151-81-00A-RED). Dimensions : Millimetres This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC MULTICOMP is the registered trademark of the Group. © Premier Farnell plc 2009. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. DRAWN BY: Jagan CHECKED BY: DATE: DRAWING TITLE: 13/02/10 DATE: Sreejesh APPROVED BY: 13/02/10 Farnell 01/03/10 DATE: SIZE A DWG NO. SCALE: NTS Neon Indicator - Rear Panel Mounting M10002498 U.O.M.: mm REV ELECTRONIC FILE 320138-DWG SHEET: 1 A OF 2 REVISIONS PART NO. 3151-81 - Series ECN # REV - A DESCRIPTION RELEASED DRAWN Jagan DATE CHECKD DATE 13/02/10 Sreejesh 13/02/10 APPRVD DATE Farnell 01/03/10 Specifications Table Length (Excluding Leads) Depth Behind Panel Lens Diameter 31 9 2.5 x 12.0 30 9.2 2.3 31 9 2.5 x 12.0 This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC MULTICOMP is the registered trademark of the Group. © Premier Farnell plc 2009. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. Panel CutOut Diameter Maximum Panel Thickness 9.5 DRAWN BY: Jagan CHECKED BY: 2.0 Colour Part Number Red 3151-81-02A Amber 3151-81-03A Green 3151-81-05A DATE: DRAWING TITLE: Neon Indicator - Rear Panel Mounting 13/02/10 DATE: Sreejesh APPROVED BY: 13/02/10 Farnell 01/03/10 DATE: SIZE A DWG NO. SCALE: NTS M10002498 U.O.M.: mm REV ELECTRONIC FILE 320138-DWG SHEET: 2 A OF 2
3151-81-05A 价格&库存
很抱歉,暂时无法提供与“3151-81-05A”相匹配的价格&库存,您可以联系我们找货
