DSI-EV32P-3C
DSI-EV32P-3C
    MULTICOMP
DSI-EV32P-3C 数据手册
REVISIONS PART NO. DSI-EV32P-3C ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED SK 18/04/12 ER 18/04/12 ER 18/04/12 Features •  •  •  •  •  •  IP54 Rated Ergonomic Pistol Grip Style Impact Resistant ‘Run Over’ Proof 10,000 Mating Cycles Cable Strain Relief Feature Insulated Terminal Design 32 Amp Cable 3G 6.0 + 2 × 0.5mm ≤ Orange Specification Current and Voltage Signal Current Protection Degree Charging Cable : 32A 240V AC : 2A < 30V DV : IP44 : 32A 1P + N + PE + PP + CP Cable Specification Function 32A 240V Color L1 (1) 6mm2 Beige N (2) 6mm PE (3) 6mm2 Green Yellow Blue CP (4) 0.5mm2 Salmon PP (5) - - 2 The Plug was designed according to the standard of SAE J1772-2010 The static resistance is 150ohm, and the resistance will increase to 480ohm when pressing the button. Charging Cable : 3,000mm / 5,000mm 3 × 6mm2 + 2 - 0.5mm2 3000/5000mm Part Number Table Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: SK UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER Description Part Number Plug EV J1772 32A 3M Cable DSI-EV32P-3C DATE: 18/04/12 DRAWING TITLE: Plug 32A 3M Cable DATE: SIZE 18/04/12 A4 DATE: 18/04/12 www.element14.com www.farnell.com www.newark.com DWG NO. DSI-EV32P-3C-01 SCALE: NTS ELECTRONIC FILE REV DSI-EV32P-3C-1 1.0 U.O.M.: mm (inch) SHEET: 1 of 1
DSI-EV32P-3C 价格&库存
很抱歉,暂时无法提供与“DSI-EV32P-3C”相匹配的价格&库存,您可以联系我们找货
