25.205.1
25.205.1
    MULTICOMP
    MULTICOMP - 25.205.1 - Banana Test Connector, 2mm, Plug, In Line Mount, 10 A, 60 V, Gold Plated Cont...
25.205.1 数据手册
In-Line 2mm Banana Plug 25.205.1 25.205.2 Features •  High Reliability •  High Stability •  Economical and Practical Typical Characteristic Body Material Insulation Material Contact Resistance Spring Material Surface Coating Rated Voltage/Current : Brass : PVC : ≤ 0.005Ω : Beryllium Copper : Gold Plated : 30V AC ~ 60V DC/ Max. 10A Diagram Dimensions : Millimetres Part Number Table Description Part Number In-Line 2mm Banana Plug, Red 25.205.1 In-Line 2mm Banana Plug, Black 25.205.2 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com Page 06/04/18 V1.0
25.205.1 价格&库存
很抱歉,暂时无法提供与“25.205.1”相匹配的价格&库存,您可以联系我们找货
