CM3502
CM3502
    MULTICOMP
CM3502 数据手册
Single Phase Bridge Rectifiers CM3500 Series Features: •  E  lectrically isolated metal case for maximum heat dissipation •  Surge overload ratings to 400 amperes Specifications: Mechanical Data Case Terminals Mounting Position : Metal, electrically isolated : Plated 0.25 inches faston : Any CM Series Dimensions : Inches (Millimetres) www.element14.com www.farnell.com www.newark.com Page 04/02/15 V1.1 Single Phase Bridge Rectifiers CM3500 Series Maximum Ratings and Electrical Characteristics: Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Parameter CM3501 CM3502 CM3504 CM3506 CM3508 CM35010 Maximum Recurrent Peak Reverse Voltage 100 200 400 600 800 1,000 Maximum RMS Bridge Input Voltage 70 140 280 420 560 700 Maximum DC Blocking Voltage 100 200 400 600 800 1,000 Unit V Maximum Average Forward Current TA == 55°C 35 Non-Repetitive Peak Forward Surge Current, Rated Load 400 Maximum Forward Voltage Per Bridge Element specified Current at 17.5 A 1.2 V Maximum Reverse Current at Rated DC Blocking Voltage Per Element 10 I-A I2t Rating for Fusing (t < 8.35 ms) 664 A2S Typical Thermal Resistance (Figure 3) RθJC 2.5 °C -55 to +150 °C Operating Temperature Range TJ Storage Temperature Range TA A Note : * Unit mounted on metal heat-sink Rating and Characteristic Curves: Figure 1 Output Current VS. Case Temperature Resistive or Inductive Load TJ = 150°C Figure 2 Typical Instantaneous Forward Characteristics at TJ = 25°C www.element14.com www.farnell.com www.newark.com Page 04/02/15 V1.1 Single Phase Bridge Rectifiers CM3500 Series Figure 3 Output Current VS. Ambient Temperature Resistive or Inductive Load Bridge Mounted on 8 × 8 Inches Aluminium Plate 0.25 Inches Thick Figure 4 Power Dissipation VS. Average Output Current Resistive or Inductive Load TJ = 150°C Part Number Table Description Single Phase Bridge ­Rectifiers CM3500 Series Current Rating (A) 35 VRRM (V) Maximum AC Input Voltage (V) Part Number 100 70 CM3501 200 140 CM3502 400 280 CM3504 600 420 CM3506 800 500 CM3508 1,000 800 CM35010 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 04/02/15 V1.1
CM3502 价格&库存
很抱歉,暂时无法提供与“CM3502”相匹配的价格&库存,您可以联系我们找货
