DSIEC-EV32P-NC
DSIEC-EV32P-NC
    MULTICOMP
DSIEC-EV32P-NC 数据手册
REVISIONS PART NO. DSIEC-EV32P-NC ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED AB 18/04/12 ER 18/04/12 ER 18/04/12 Features •  •  •  •  •  •  IP54 Rated Ergonomic Pistol Grip Style Impact Resistant ‘Run Over’ Proof 10,000 Mating Cycles Cable Strain Relief Feature Insulated Terminal Design 32amp Cable 5G6.0 + 2 × 0.5mm² Orange Specification Current and Voltage Signal Current Protection Degree Charging Cable Charging Cable : 32A 240V AC : 2A < 30V DV : IP44 : 32A 1P + N + PE + PP + CP : 3,000mm / 5,000mm 3 × 6mm² + 2 - 0.5mm² The plug II, was designed according to the standard of 62196-2 IEC 2010 sheet 2-IIb Smooth line design The static resistance is 220 ohm Cable Specification Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. Function 32A 240V L1 (1) 6mm2 L2 (2) - L3 (3) - N (4) 6mm2 PE (5) 6mm2 CP (6) 0.5mm2 PP (7) - TOLERANCES: DRAWN BY: AB UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 18/04/12 Part Number Plug EV 62196-2 32A DSIEC-EV32P-NC www.element14.com www.farnell.com www.newark.com Plug EV 62196-2 32A SIZE 18/04/12 A4 18/04/12 Description DRAWING TITLE: DATE: DATE: Part Number Table DWG NO. DSIEC-EV32P-NC-01 SCALE: NTS ELECTRONIC FILE REV DSIEC-EV32P-NC-1 1.0 U.O.M.: mm (inch) SHEET: 1 of 1
DSIEC-EV32P-NC 价格&库存
很抱歉,暂时无法提供与“DSIEC-EV32P-NC”相匹配的价格&库存,您可以联系我们找货
