HDD100-24S24T
HDD100-24S24T
    MULTICOMP
HDD100-24S24T 数据手册
HDD100 SERIES DC - DC CONVERTER 100W SINGLE OUTPUT FEATURES 100W DC / DC CONVERTER 2:1 INPUT RANGE, Pi INPUT FILTER ISOLATION INPUT AND OUTPUT HIGH PERFORMANCE UP TO 86% SHORT CIRCUIT PROTECTION 2 YEARS WARRANTY MODEL LIST OUTPUT CURRENT EFF. (min.) 5 VDC 20000 mA 80% + 12 VDC 8300 mA 84% 6600 mA 84% 4000 mA 85% 20000 mA 83% MODEL NO. INPUT VOLTAGE HDD100 - 24S05-X 18~36 VDC 100 WATTS + HDD100 - 24S12-X 18~36 VDC 100 WATTS HDD100 - 24S15-X 18~36 VDC 100 WATTS + 15 VDC HDD100 - 24S24-X 18~36 VDC 100 WATTS + 2 4 VDC HDD100 - 48S05-X 36~72 VDC 100 WATTS + 5 VDC HDD100 - 48S12-X 36~72 VDC 100 WATTS + 12 VDC 8300 mA 85% HDD100 - 48S15-X 36~72 VDC 100 WATTS + 15 VDC 6600 mA 85% HDD100 - 48S24-X 36~72 VDC 100 WATTS + 2 4 VDC 4000 mA 86% OUTPUT OUTPUT WATTAGE VOLTAGE Single Output Models SUFFIX "X=P" : PCB MOUNTING TYPE, HEAT SINK WILL BE ADDED ON MODULE. SUFFIX "X=T" : CHASSIS MOUNTING TYPE:(TERMINAL BLOCK), NO HEAT SINK. USE CHASSIS AS HEAT SINK OR FAN FORCE COOLING. INDICATE SUFFIX WHEN ORDER. . CIRCUIT SCHEMATIC Block diagram for HDD100 series with single output Vo + Vi + Switching Device Rectifier S+ Vo - Vi - PWM Controller Opto Isolation Reference & Error Amp. STrim ON / OFF www.chinfa.com sales@chinfa.com HDD100 SERIES SINGLE OUTPUT SPECIFICATION o All Specifications Typical At Nominal Line, Full Load, 25 C Unless Otherwise Noticed GENERAL Characteristics Conditions min. Switching frequency Vi nom, Io nom Isolation voltage Input / Output Isolation resistance Input / Output, @ 500VDC 1G Ambient temperature Operating at Vi nom, Io nom -25 Case temperature Operating at Vi nom, Io nom typ. max. 80 KHz 1,500 Derating Vi nom Storage temperature Non operational M.T.B.F. According to MIL-HDBK-217F, GF40 Dimension L88.9 x W139.7 x H42.4 for "P" type Cooling Free air convection Case material Metal unit VDC + 71 o + 100 o C C o See derating curve -25 %/ C o +100 C 100,000 Hrs mm mm L88.9 x W139.7 x H32.9 for "T" type INPUT SPECIFICATIONS Characteristics Input voltage range Conditions min. Ta min ... Ta max, Io nom No load input current Vi = nom, Io=0 Input voltage w/o damage Io nom Input filter Pi type typ. max. unit 18 24 36 VDC 36 48 48 72 VDC 24V models 20 mA 48V models 15 mA 24V models 40 VDC 48V models 75 VDC OUTPUT SPECIFICATIONS Characteristics Conditions min. typ. max. unit Output voltage accuracy Vi nom, Io nom Minimum load Vi nom Line regulation Io nom, Vi min ...Vi max 1 % Load regulation Vi nom, Io min ...Io nom 2 % Transient recovery time 25% load, step changed Temperature coefficient Vi nom, Io nom 0.02 % / oC Ripple & noise Vi nom, Io nom, BW = 20MHz Voltage trim range Vi nom Efficiency Vi nom, Io nom, Po / Pi % 1 0 % S 500 Vout x 10 1% mV % Up to 86%, See model list CONTROL AND PROTECTION Remote ON / OFF ON: opened or +5.5VDC applied, reference to input GND OFF: -1.8VDC applied, reference to input GND Input reversed Shunt diode built in, external fuse recommended Output short circuit Continuous www.chinfa.com sales@chinfa.com HDD100 SERIES SINGLE OUTPUT MECHANISM & PIN CONFIGURATION REMOTE ON / OFF CONTROL EXTERNAL OUTPUT TRIMMING TERMINAL 6 CONTROL LOGIC COMPATIBILITY : ..............OPEN COLLECTOR TTL CONTROL VOLTAGE. ON +5.5V MIN. OR OPEN CIRCUIT. OFF ......+1.8V MAX. CONVERTER SHUTDOWN IDLE CURRENT ..............10 mA CONTROL COMMON ..........................INPUT TERMINAL 2 12 12 Trim Up or 13 14 TP 4-40 x 4 139.70 [5.50] PCB Mounting Type Suffix P 19.05 [0.75] 9.53 9.53 9.53 9.53 9.53 9.53 5.59 [0.22] 109.22 [4.30] Trim Down 14 6.35 [0.25] 22.35 [0.88] 13 Trim Down CASE : HH- P- 100 20.04 [0.79] Trim Up 8 9 10 11 12 13 14 2 3 4 5 6 7 [0.37] [0.37] [0.37] [0.37] [0.37] [0.37] 9.53 9.53 9.53 9.53 9.53 9.53 9.53 9.53 [0.37] [0.37] [0.37] [0.37] [0.37] [0.37] [0.37] [0.37] 6.35 [0.25] BOTTOM VIEW 15.24 [0.60] CASE : HH- T 6.35 [0.25] 139.70 [5.50] 19.05 [0.75] 9.53 [0.37] 9.53 9.53 9.53 9.53 9.53 22.35 [0.88] 10.5 [0.41] [0.37] [0.37] [0.37] [0.37] [0.37] TP 4-40 x 4 Terminal Block Type Suffix T 8 9 2 10 3 11 4 5 12 6 13 7 14 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 9.53 [0.37] 6.35 [0.25] 15.24 [0.60] BOTTOM VIEW PHYSICAL CHARACTERISTICS CASE SIZE 88.9 x 139.7 x 42.4 mm 3.5 x 5.5 x 1.67 inches for "P" type CASE MATERIAL Metal WEIGHT 710 g for "P" type / 570 g for "T" type 88.9 x 139.7 x 32.9 mm 3.5 x 5.5 x 1.29 inches for "T" type PIN ASSIGNMENT DERATING GENERAL 1 2&3 SINGLE NO PIN 4&5 Vi + 6 REMOTE ON/OFF CONTROL 7 N. C. 8 Vo - 9 Vo - 10 Vo + 11 Vo + 12 SENSOR - 13 Trim 14 SENSOR + www.chinfa.com 100 Vi - NATURAL CONVECTION Power out [ % ] PIN NO. COOLING 0 -25 71 100 o Ambient Temperature [ C ] sales@chinfa.com
HDD100-24S24T 价格&库存
很抱歉,暂时无法提供与“HDD100-24S24T”相匹配的价格&库存,您可以联系我们找货
