25.412.1
25.412.1
    MULTICOMP
    MULTICOMP - 25.412.1 - Banana Test Connector, 4mm, Plug, Cable Mount, 24 A, 30 VAC, Nickel Plated Co...
25.412.1 数据手册
REVISIONS PART NO. 25.412 - Series ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED SAN 17/03/15 ER 17/03/15 ER 17/03/15 Dimensions : Millimetres Specification: Material : Brass body steel spring nickel plated with PVC housing Part Number Table Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: SAN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER Description Part Number Plug, 4mm, Red 25.412.1 Plug, 4mm, Black 25.412.2 Plug, 4mm, Blue 25.412.5 Plug, 4mm, Yellow 25.412.3 Plug, 4mm, Green 25.412.4 DATE: 17/03/15 DRAWING TITLE: 4mm Banana Plug DATE: SIZE 17/03/15 A4 DATE: 17/03/15 www.element14.com www.farnell.com www.newark.com DWG NO. SCALE: NTS ELECTRONIC FILE M10002188 U.O.M.: mm REV 25.412_DWG SHEET: 1 of 1 1.0
25.412.1 价格&库存
很抱歉,暂时无法提供与“25.412.1”相匹配的价格&库存,您可以联系我们找货
