2KBP02M..
2KBP02M..
    MULTICOMP
    MULTICOMP - 2KBP02M.. - Bridge Rectifier, Single Phase, 50 V, 2 A, SIP, 4 Pins, 1.1 V
2KBP02M.. 数据手册
Bridge Rectifier Features: •  •  •  •  In-line glass passivated single phase rectifier bridge Surge overload rating: 60 Amperes peak Ideal for printed circuit board Reliable low cost construction utilizing moulded plastic technique Mechanical Data: Terminals Mounting position Weight : Lead solderable per MIL-STD-202, Method 208 : Any : 0.06oz, 1.7g Maximum Ratings and Electrical Characteristics: Ratings at 25°C ambient temperature unless otherwise specified. Resistive or inductive load, 60Hz. Parameter 2KBP02M 2KBP08M Maximum recurrent peak reverse voltage 200 800 Maximum RMS bridge input voltage 140 560 Maximum DC blocking voltage 200 800 Maximum average rectified output current at 25°C ambient 2 Peak one cycle surge overload current 60 Maximum forward voltage drop per bridge element at 3.14A DC 1.1 Maximum (Total bridge) reverse leakage at rated DC blocking voltage 5 Units V A V mA Maximum (Total bridge) reverse leakage at rated DC blocking voltage and 100°C 0.5 I2t Rating for fusing ( t
2KBP02M.. 价格&库存
很抱歉,暂时无法提供与“2KBP02M..”相匹配的价格&库存,您可以联系我们找货
