2TJ3000-W05102
2TJ3000-W05102
    MULTICOMP
2TJ3000-W05102 数据手册
Cable Assembly RJ45, CAT5E Specifications: Waterproof rate IP67 Rating Connector Type A Connector Type B Cable Length - Imperial Jacket Colour Cable Length : IP67 (when properly mated) : Immersed in 1M water for 30 minutes : 125V 1.5A : RJ45 : RJ45 : 23.62” : Black : 600mm Dimensions : Millimetres Pin Out Conn.2 Conn.1 Specifications Table Item Description Material Plating and Colour A RJ45 Plug P/N : 2TJ300-W05100 Black Cable CAT5E FTP 24#*4P+ Mylar+D+Al/My (UV Resistant) Black PVC Jacket B Pin Assignments Front View Conn.2 Wire Color Conn.1 1 Orange/White 1 2 Orange 2 3 Green/White 3 4 Blue 4 5 Blue/white 5 6 Green 6 Description Cable L (mm) Part Number 7 Brown/White 7 Cable Assbly, RJ45, CAT5E, 0.6M L = 600 ±30 2TJ3000-W05102 8 Brown 8 Cable Assbly, RJ45, CAT5E, 3.5M L = 3500 ±150 2TJ3000-W05103 Shield Drain Shield Cable Assbly, RJ45, CAT5E, 10M L = 10000 ±400 2TJ3000-W05104 Part Number Table Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 10/10/12 V1.0
2TJ3000-W05102 价格&库存
很抱歉,暂时无法提供与“2TJ3000-W05102”相匹配的价格&库存,您可以联系我们找货
