CLB300CTP + SPC125
CLB300CTP + SPC125
    MULTICOMP
    MULTICOMP - CLB300CTP + SPC125 - LED Lens, Transparent, 7.11 mm, Dome, PC (Polycarbonate)
CLB300CTP + SPC125 数据手册
LENS MOUNTS 3mm & 5mm LEDs Visibility: CLIPLITE produces up to 180 degrees of viewing angle using standard 3 mm and 5 mm LEDs Brightness: CLIPLITE utilizes striated lines and fresnel rings to increase apparent brightness up to 125% and viewing angle up to 180 degrees with either diffused or non diffused LEDs. A low profile lens without rings or lines is available for direct sunlight applications Protection: CLIPLITE helps prevent IC failures caused by electrostatic discharge (ESD). Simply walking across a carpet can generate 10,000 volts. Introduction of this ESD thru an exposed panel mounted LED is capable of damaging or destroying a semiconductor. A CLIPLITE mounted LED helps guard components from ESD up to 16kV while affording the LED physical protection Installation: CLIPLITE, standard or low profile, requires no assembly tools; just snap into a panel opening and insert LED. Cost effective operation is complete in only 6 seconds Specifications: Material : Lense - polycarbonate Spacer - nylon. (U.L. listed materials) Design : Standard and low profile lens with fresnel rings and striated lines CLR301 low profile lens is available without fresnel rings Mounting : Mounts thru front of panel Mounting holes should be deburred but not chamfered 3 mm (SML 190, SMB 200) mounts in a .171 ± 0 .002 (4.34 mm) hole on 1/4 inches centre Panel thickness for SML 190, 1/32 inches to 1/16 inches; SMB 200, 1/16" to 1/8", 5 mm (CLF 280, CLB 300, CLR 301) mounts in a 0.25 ± .002 (6.35 mm) hole on 3/8 inches centre Panel thickness for CLF 280, 1/16 inches to 1/8 inches; CLB 300 and CLR 301, 1/32 inches to 1/4 inches; for panels less than 3/16 inches, use SPC 125 spacer. www.element14.com www.farnell.com www.newark.com Page 14/01/12 V1.1 LENS MOUNTS 3mm & 5mm LEDs Simple Two-Step Installation 1. Snap the CLIPLITE into the panel hole 2. While holding the CLIPLITE tight to the panel with your finger, insert the LED into the CLIPLITE from the back Recommended LEDs Outline Drawings www.element14.com www.farnell.com www.newark.com Page 14/01/12 V1.1 LENS MOUNTS 3mm & 5mm LEDs Ordering Codes CLB 300 Model CLB 300 (5 mm) L/Profile. + RTP Colour RTP ATP GTP BTP YTP CTP SPC125 Spacer Red Transparent Amber Transparent Green Transparent Blue Transparent Yellow Transparent Clear Transparent Part Number Table Description Part Number Lens/Mount, Red CLB300RTP + SPC125 Lens/Mount, Amber CLB300ATP + SPC125 Lens/Mount, Yellow CLB300YTP + SPC125 Lens/Mount, Green CLB300GTP + SPC125 Lens/Mount, CLR CLB300CTP + SPC125 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 14/01/12 V1.1
CLB300CTP + SPC125 价格&库存
很抱歉,暂时无法提供与“CLB300CTP + SPC125”相匹配的价格&库存,您可以联系我们找货
