FR307G
FR307G
    MULTICOMP
FR307G 数据手册
Diode - Fast Features: •  •  •  •  •  •  Glass passivated chip junction High efficiency, low VF High current capability High reliability High surge current capability Low power loss Specifications: Mechanical Data: Cases : Moulded plastic Lead : Pure tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed Polarity : Colour band denotes cathode end High temperature soldering guaranteed : 260°C/10 seconds/0.375 inch, (9.5mm) lead lengths at 5lbs., (2.3kg) tension Mounting position : Any Weight : 1.2 grams Maximum Ratings and Electrical Characteristics: Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol FR302G FR305G FR307G Maximum Recurrent Peak Reverse Voltage Vrrm 100 600 1000 Maximum RMS Voltage Vrms 70 420 700 Maximum DC Blocking Voltage Vdc 100 600 1000 Maximum Average Forward Rectified Current 0.375 inch (9.5mm) Lead Length at Ta = 55°C I(av) Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method ) Ifsm 125 Vf 1.3 Maximum Instantaneous Forward Voltage at 3A Units V 3 A V www.element14.com www.farnell.com www.newark.com Page 05/02/13 V1.0 Diode - Fast Type Number Symbol FR302G FR305G FR307G Units Maximum DC Reverse Current at Ta = 25°C at Rated DC Blocking Voltage at Ta = 125°C Ir Maximum Reverse Recovery Time (Note 1) Trr Typical Junction Capacitance (Note 2) Cj 30 pF RθJA 35 °C/W -65 to +150 °C Typical Thermal Resistance Operating Temperature Range Storage Temperature Range 5 100 150 Tj Tstg 250 μA μA 500 nS Note: 1. Reverse Recovery Test Conditions: IF = 0.5A, IR = 1A, IRR = 0.25A. Note: 2. Measured at 1MHz and Applied Reverse Voltage of 4 Volts DC. Note: 3. Mount on Cu-Pad Size 16mm × 16mm on PCB. Ratings and Characteristic Curves (FR302G, FR305G, FR307G) www.element14.com www.farnell.com www.newark.com Page 05/02/13 V1.0 Diode - Fast www.element14.com www.farnell.com www.newark.com Page 05/02/13 V1.0 Diode - Fast Note: 1. Rise Time = 7ns Maximum. Input Impedance = 1 MΩ 22pf Note: 2. Rise Time = 10ns Maximum Source Impedance = 50Ω Part Number Table Description Part Number Diode, Fast, 3A, 100V FR302G Diode, Fast, 3A, 600V FR305G Diode, Fast, 3A, 1000V FR307G Dimensions : Inches (Millimetres) Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 05/02/13 V1.0
FR307G 价格&库存
很抱歉,暂时无法提供与“FR307G”相匹配的价格&库存,您可以联系我们找货
