FRAGILE 48MMX66M
FRAGILE 48MMX66M
    MULTICOMP
    MULTICOMP - FRAGILE 48MMX66M - Packaging Tape, PP (Polypropylene), 48 mm x 66 m
FRAGILE 48MMX66M 数据手册
Nu-Pax Limited TECHNICAL DATA SHEET FRAGILE Polypropylene Tape DESCRIPTION A self adhesive tape based on a 30 micron film with a synthetic rubber / hot melt solvent free adhesive. APPLICATIONS For medium weight packaging, designed for a wide range of corrugated and liner board boxes. For simple surface printing using regular flexographic inks. PROPERTIES Thickness Peel Adhesion Tack Rolling ball test PSTC-6 Holding Power Shelf Life : : : : : 43 micron +/-1 micron ≥ 0.6 Kg/25mm < 5cm > 24 hours 12 months in original packaging stored in cool dry conditions Date of Issue September 2013 Statements, technical information and recommendations contained herein are based on production data with properties, quoted being typical but intended only as a guide. They do not constitute a product specification nor are they to be construed in any manor as warranties expressed or implied. The user shall determine the suitability of the product for its intended use and the user assumes all risk and liability whatsoever in connection therewith. Unit 7, Spectrum Park, Spectrum Way Cheadle Heath, Cheshire, SK3 0SA Tel; 0161 968 4970 Fax; 0161 429 6612 Directors DM Tonge PR Tonge Registered in England No 372452 Registered Office Unit 7, Spectrum Park, Cheadle Heath, Cheshire, SK3 0SA
FRAGILE 48MMX66M 价格&库存
很抱歉,暂时无法提供与“FRAGILE 48MMX66M”相匹配的价格&库存,您可以联系我们找货
