HCZ-H8-B
HCZ-H8-B
    MULTICOMP
HCZ-H8-B 数据手册
Humidity Sensor Type HCZ-H8 Description This product specification is applied to the Humidity Sensor Type HCZ-H8. The terminal electrode material uses lead free solder (Sn / Ag / Cu). This product is conformity with RoHS directive which means that lead, cadmium, mercury, hexavelent chromium and specific bromine-based flame retardants have not been used. Applications The applications of the component are used in relative humidity measurement, control and display. There are many end products can be used. For example air conditioner, humidifier, dehumidifier, hygrometer, recorder, transmitter etc. Model Number HCZ - Product Type H8 Dip Type Humidity Sensor, H : ±3% RH - A With (A) / Without (B) Housing Package Each Pieces Configuration and Main Parts Configuration : (Units : mm) Symbol Dimensions (mm) A 8.3 ±0.2 B 13.5 ±0.2 C 4 ±0.5 D 15 ±2 E 2.54 ±0.2 F 0.5 ±0.1 G 0.2 ±0.1 H 2 ±0.5 I 5.08 ±0.3 J 10 ±0.3 www.element14.com www.farnell.com www.newark.com Page 04/06/11 V1.1 Humidity Sensor Type HCZ-H8 Main Parts No. Parts Reference 1 Sensor case PBT 2 Substrate Alumina 3 Sensing material Polymer 4 Electrode Ag / Carbon 5 Lead frame Phosphor bronze Electrical Characteristics General Characteristics: Units Min. Typ. Max. Rated voltage Vrms - - 1 Rated power mW - - 0.2 Operating frequency range KHz 0.5 1 2 °C 0 - 60 % RH - - 90 KΩ 22.9 - 41.9 -3 - +3 Operating temperature range Operating humidity range Impedance range at 60% RH and 25°C** Humidity accuracy % RH Hysteresis (40% RH to 80% RH) Temperature dependence (Reference) % RH / °C - 2 - 0.3 - **Measurement by LCR meter at 1 KHz, 1 Vrms (sine wave) Relative Humidity - Impedance - 25°C, 1 KHz, 1 Vrms (Sine wave) % RH Ω) Normal Value (KΩ 20 30 40 50 60 70 80 90 6,300 1,400 310 87 31 11.8 4.8 2 Relative humidity - Impedance curve is shown in page 3 Mechanical Characteristics No. Item Description 6.1 Shock resistance Drop down 3 times at 80 cm. 6.2 Vibration resistance 2 hours each in the directions of X-Y-Z, at the frequency of 10-55 Hz, and amplitude of 1.5 mm. 6.3 6.4 Resistance to soldering heat Strength of terminations Criteria* No abnormal appearance and electrical properties. The lead terminal shall be immersed by 3 mm from the substrate for 3 s in solder bath of 330 ±5°C. 500 g at 10 s in the axial direction of lead terminal. Secured www.element14.com www.farnell.com www.newark.com Page 04/06/11 V1.1 Humidity Sensor Type HCZ-H8 Reliability No. Item Description Criteria* 7.1 Heat resistance 1,000 hrs at 70°C 7.2 Cool resistance 1,000 hrs at -30°C 7.3 Humidity resistance 1,000 hrs at 60°C, 90% RH Humidity cycle Repeat 1,000 cycles One cycle: 30 mins at 25°C, < 20% RH 30 mins at 25°C, > 90% RH 7.4 7.5 Temperature cycle Repeat 100 cycles Each cycle: 30 mins at -30°C 30 mins at 85°C 7.6 Voltage resistance 3,000 hrs at 1 KHz, 1 Vrms < ±3% RH * The criteria test that the sensors finish the description process after 2 hours under normal temperature and humidity, The test condition is fixed at 25°C, 60% RH by LCR meter at 1 KHz, 1 Vrms (sine wave). References Relative Humidity-Impedance Curve-Measured at 1 KHz, 1 Vrms (sine wave) www.element14.com www.farnell.com www.newark.com Page 04/06/11 V1.1 Humidity Sensor Type HCZ-H8 Impedance - % RH vs. Temperature Unit: KΩ RH% 5°C 10°C 15°C 20°C 25°C 30°C 35°C 40°C 45°C 50°C 55°C 60°C 20 - 15,000 11,000 8,200 6,300 4,900 4,000 3,300 2,800 2,500 2,200 2,100 25 10,000 7,400 5,300 3,900 3,000 2,300 1,800 1,500 1,300 1,100 1,000 920 30 4,800 3,400 2,400 1,800 1,400 1,100 870 710 600 510 450 410 35 2,100 1,500 1,100 820 630 490 390 320 270 230 200 180 40 980 700 520 400 310 240 190 160 130 110 100 91 45 480 350 260 200 160 120 100 86 73 63 55 50 50 250 190 140 110 87 74 61 51 44 38 34 30 55 130 100 80 64 49 43 36 30 26 23 21 19 60 73 57 46 37 31 26 22 19 17 15 14 13 65 41 32 27 22 19 16 14 12 11 10 9.2 8.6 70 23 19 16 14 11.8 10.2 9.1 8.2 7.5 6.9 6.5 6.1 75 13 11 9.5 8.4 7.5 6.7 6.1 5.6 5.2 4.9 4.6 4.4 80 7.2 6.4 5.8 5.2 4.8 4.4 4.1 3.8 3.6 3.4 3.3 3.2 85 4 3.7 3.5 3.3 3 2.9 2.8 2.6 2.5 2.4 2.4 2.3 90 2.2 2.2 2.1 2 2 1.9 1.8 1.8 1.7 1.7 1.7 1.6 Part Number Table Description Humidity Sensor Part Number HCZ-H8-B HCZ-H8-A Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. www.element14.com www.farnell.com www.newark.com Page 04/06/11 V1.1
HCZ-H8-B 价格&库存
很抱歉,暂时无法提供与“HCZ-H8-B”相匹配的价格&库存,您可以联系我们找货
