09-4570-25-05
09-4570-25-05
    BERKER
09-4570-25-05 数据手册
The Berker Integro range is designed for use in: • • • • • Yachts, boats, caravans, static and motor homes Laboritories Electrical equipment such as PATs, electrical distribution boxes and power sockets Furniture such as office furniture and bathroom mirror cabinets Power tools and cleaning equipment Berker products are widely known for: • • • • Ultra compact designs and minimal installation depths - ideal for applications where space is a premium. Ease of installation – no special tool requirements Outstanding quality Modern and forward thinking design concepts Berker Part No. 09-1827-25-09 – Frame 1 gang 09-1826-25-19 – Frame 2 gang 09-3651-25-09 – Rocker switch 09-4185-25-02 – SCHUKO socket outlet 09-6262-25-02 – British standard socket outlet 09-4570-25-05 – Motor vehicle power socket outlet 1980 – Mini jack 8 pole 09-1828-25-99 – Frame with hinged cover and IP44 imprint 09-1853 – Seal • • • • • • • • • • • • • • • • • • • • • • • • • 19820 – Wall box 45mm Ø • • • • • • Technical details Polar white, glossy For vertical and horizontal mounting Polar white, glossy, off 16AX 250V Suitable for all Berker Integro wall boxes Suitable for all Berker Integro wall boxes Connection terminals IEC 60884-1 DIN 49440 With screw terminals 13A, 250V Suitable for all Berker Integro wall boxes Standard BS 1363 2 pole and earth With screw terminals 6-24V, 20A at 2.5mm², 15A at 1.5mm² Not suitable for wall boxes With flat plug connection Black, RJ45, cat.3 ISDN-compatible Protective screen DIN EN 55022 class B Colour code A and B EIA/TIA 568A With insulation piercing terminals Protection class IP44 only guaranteed when used with seal 09-1853 For the cover on socket outlets For rocker switches and push buttons For SCHUKO socket outlets and socket outlets with earth pin Use with 09-1828-25-99 for IP44 protection Grey with cable clamp Insertion depth 35.5mm Flame resistant according to VDE 0606-1 For switches and socket outlets With 4 line entries 3 knockout openings
09-4570-25-05 价格&库存
很抱歉,暂时无法提供与“09-4570-25-05”相匹配的价格&库存,您可以联系我们找货
