3140 06 08
3140 06 08
    OTHER
3140 06 08 数据手册
pneumatic push-in fittings ® system LF 3000 of system LF 3000® Principle Invented and launched by Legris in 1969, the LF 3000® system has become universally adopted. It has been designed using a simple and widely proven operating principle which allows instant fitting. The connection of tube to fitting is made by simply pushing the tube into the fitting, no other operation is required. Disconnection is similarly "instantaneous". Attentive to market needs, Legris has taken into account the requirements of its customers, i.e. optimisation of performance, miniaturization and appearance. In order to be utilised to its maximum capability, the LF 3000® system is available in 3 ranges : - for metric tubing with BSP threads in taper, parallel or metric form. - for fractional inch tubing with BSP threads in taper form. - for fractional inch tubing with NPT threads. Millions of fittings are in service throughout the world. Designed for pneumatic installations, the LF 3000® system is therefore an essential component in a wide variety of industries. technical specifications Reliable performance is dependent upon the type of tubing suitable fluids being used, ambient temperature and fluid conveyed together with the suitability of component materials of the fitting, according to the application. gripping ring plastic body compressed air LF 3000® can also be used for conveying various types of liquids (water, cutting oil, etc) for industrial applications. The working pressure, from 0 to 6 / 10 bar, and temperatures, from 0 to 60°C, are dependent upon the fluid conveyed and the type of 'O' ring used. For further information, please consult us. working pressure 20 bar maximum Maximum circuit pressure depends equally on the type and diameter of tubing used. vacuum capability vacuum of 755 mm Hg (99% vacuum) working temperature -20° to +80°C The fitting’s suitability depends equally on the type and OD of the tube used. For temperature above 80°C, please consult us. constituent materials body : glass reinforced nylon 6.6 collar : nylon gripping ring : stainless steel "O" rings : nitrile (EPDM, FPM upon request) sub-base : nickel-plated brass (stainless steel upon request) release button sealing "O" ring sealing "O" ring on BSPP threads, and precoating on BSPT threads All items in the LF 3000 ® range are guaranteed SILICONE FREE maximum tightening torque for LF 3000® fittings, BSPP threads, M5 and M7 Thread M3 M5 M7 G1/8“ G1/4“ G3/8“ G1/2“ x 0,5 x0,8 x1 m. da N 0,06 0,16 0,8 0,8 1,2 3 3,5 of system LF 3000® Advantages PERFORMANCE AND RELIABILITY ● full flow : as gripping and sealing within the fitting is achieved using the outside of the tube without deformation, there is no flow restriction. ● automatic sealing : the 'O' ring within the fitting provides a positive seal on the O.D. of the tube, in both static and dynamic positions, due to the optimized design of the tube guide. ONE OF THE MOST EXTENSIVE RANGES ON THE MARKET ● a solution for all applications : wide variety of body designs and numerous configurations, from 3 mm to 14 mm diameters. ● 3 types of thread : BSP parallel, BSP taper and metric. ● special items on request. COMPACT AND AESTHETIC ● optimized dimensions and new body designs, to satisfy the ergonomics and aesthetics of pneumatic installations. LIGHT WEIGHT ● a feature introduced for improved performance, mobility and productivity. INSTANT CONNECTION AND DISCONNECTION ● IMMEDIATE SEAL ● ● disconnection without the use of spanners. for parallel threaded fittings, due to a patented built in captive 'O' ring seal. instant connection and ● release buttons : for tapered threaded fittings due to available in 5 colours, to pre-coating. identify different circuits. Our production process includes individual unit quality control and dating, for all LF 3000 ® push-in fittings, in order to guarantee their quality and traceability. LF 3000® pneumatic push-in fittings can be used with various Legris technical tubing semi-rigid close tolerance nylon tubing Main advantages of use of Legris nylon tubing with LF 3000® push-in fittings ● large range of working temperatures and pressures ● small pressure drop ● constant rigidity, good ageing ● good absorbtion of vibration ● 7 colours for easy identification of circuits - 3 mm to 16 mm O.D. - in 25 m rolls: part number 1025P - in 100 m rolls: part number 1100P close tolerance flexible polyurethane tubing Main advantages of use of Legris polyurethane tubing with LF 3000® push-in fittings ● high flexibility and small bend radius ● large range of working temperatures and pressures ● small pressure drop ● constant rigidity, good ageing ● good absorbtion of vibration ● 7 colours for easy identification of circuits - 3 mm to 14 mm O.D. - 2 ranges: polyester and polyether tubing - in 25 m rolls: ● polyester polyurethane, part number 1025U ● polyether polyurethane, part number 1025U..R - in 100 m rolls: Legris polyurethane tubing is supplied in tubepack® boxes easy storage protection of tubing against outside aggression ● easy dispensing of the tube ● immediate visual identification of tubing ● ● ● polyester polyurethane, part number 1100U ● polyether polyurethane, part number 1100U..R You can find LF 3000® push-in fittings on legris.com online catalogue ● with the online catalogue, regularly updated, you can 3104 equal and unequal tee easily find the whole range of LF 3000 ® for metric and inch tubing. - you can find a product quickly thanks to 3 search options - you can get a complete product datasheet with a photo, technical drawing and specifications - you can ask for a quotation from our distributors - you can download CAD drawings for free learning space ● with the learning space designed to optimize find animated presentations performance of your installations, you will find animated presentations of LF 3000 ® fittings and their functions: - instant connection and disconnection - applications and solutions to match your equipment requirements www.legris.com tube to tube fittings 3140 single "Y" piece - equal and unequal 3144 ØD1 ØD2 ØD2 ØD1 3106 double "Y" piece - equal and unequal ØD1 ØD2 ØD2 4 6 8 10 12 4 6 8 10 12 3140 3140 3140 3140 3140 04 06 08 10 12 00 00 00 00 00 4 6 8 10 6 8 10 12 3140 3140 3140 3140 04 06 08 10 06 08 10 12 ØD1 3102 ØD 4 6 4 6 3144 04 04 3144 06 06 4 6 6 8 3144 04 06 3144 06 08 4 6 8 10 12 14 Ø D 03 04 06 08 10 12 14 00 00 00 00 00 00 00 3102 3 4 6 8 10 12 14 3104 ØD 3106 3106 3106 3106 3106 3106 3106 equal tee 3104 3104 3104 3104 3104 3104 3104 03 04 06 08 10 12 14 00 00 00 00 00 00 00 3104 3104 3104 3104 3104 3104 3104 3104 3104 04 06 06 08 08 10 10 12 14 06 04 08 06 10 08 12 10 08 04 06 08 10 12 14 00 00 00 00 00 00 equal elbow tube/tube connector 3 4 6 8 10 12 14 3104 3102 3102 3102 3102 3102 3102 04 06 08 10 12 14 00 00 00 00 00 00 unequal tee ØD1 ØD2 ØD1 unequal elbow ØD2 4 6 6 8 8 ØD1 10 10 12 14 6 4 8 6 10 8 12 10 8 ØD1 ØD2 3106 unequal tube/tube connector ØD1 ØD1 ØD2 3 4 4 6 6 8 ØD2 8 10 12 ØD1 4 6 8 8 10 10 12 12 14 ØD2 3106 3106 3106 3106 3106 3106 3106 3106 3106 03 04 04 06 06 08 08 10 12 4 6 8 10 6 8 10 12 3102 3102 3102 3102 04 06 08 10 06 08 10 12 04 06 08 08 10 10 12 12 14 bulkhead connector fittings 3116 bulkhead connector 3136 ØD 4 6 8 10 12 14 3116 3116 3116 3116 3116 3116 04 06 08 10 12 14 00 00 00 00 00 00 3146 female bulkhead connector, BSPP thread ØD C 4 4 6 6 6 8 8 10 12 12 G1/8 G1/4 G1/8 G1/4 G3/8 G1/8 G1/4 G3/8 G3/8 G1/2 3139 equal bulkhead elbow ØD 3136 3136 3136 3136 3136 3136 3136 3136 3136 3136 04 04 06 06 06 08 08 10 12 12 10 13 10 13 17 10 13 17 17 21 4 6 8 10 12 14 3139 3139 3139 3139 3139 3139 mixed bulkhead connector ØD All plastic nuts are fitted with an 4 6 8 10 12 14 “O” ring to optimise sealing to a panel 3146 3146 3146 3146 3146 3146 04 06 08 10 12 14 00 00 00 00 00 00 self-sealing fittings 3391 self-sealing male stud fitting, BSPP thread ØD C 4 6 8 8 10 G1/8 G1/8 G1/8 G1/4 G3/8 3391 3391 3391 3391 3391 04 06 08 08 10 10 10 10 13 17 3091 self-sealing male stud fitting, BSPT thread ØD C 4 6 8 8 10 R1/8 R1/8 R1/8 R1/4 R3/8 3160 self-sealing plug-in fitting ØD 3091 3091 3091 3091 3091 04 06 08 08 10 10 10 10 13 17 4 6 8 3160 04 00 3160 06 00 3160 08 00 threaded fittings 3114 3109 female stud fitting with BSPP and M5 thread ØD C 4 4 4 6 6 8 8 8 10 10 10 12 12 14 M5x0,8 G1/8 G1/4 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G3/8 G1/2 G3/8 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 14 14 3124 3118 04 04 04 06 06 08 08 08 10 10 10 12 12 14 3109 04 10 3109 04 13 3109 04 17 3109 06 10 3109 06 13 3109 06 17 3109 06 21 3109 08 10 3109 08 13 3109 08 17 3109 08 21 3109 10 10 3109 10 13 3109 10 17 3109 10 21 3109 12 13 3109 12 17 3109 12 21 3109 14 17 3109 14 21 3133 ØD C 4 4 4 4 6 6 6 6 8 8 8 10 10 10 12 12 12 14 14 M5x0,8 M7x1 G1/8 G1/4 M5x0,8 M7x1 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 3169 04 04 04 04 06 06 06 06 08 08 08 10 10 10 12 12 12 14 14 19 55 10 13 19 55 10 13 10 13 17 13 17 21 13 17 21 17 21 4 4 6 6 6 8 8 8 10 10 10 12 12 12 3129 single banjo with female BSPP bolt, M5 and BSPP thread ØD C 4 4 6 8 M5x0,8 G1/8 G1/4 G3/8 3124 3124 3124 3124 04 04 06 08 19 10 13 17 3018 ØD 3 3 4 4 6 6 6 8 8 8 10 10 10 12 12 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 3118 03 03 04 04 06 06 06 08 08 08 10 10 10 12 12 09 19 19 10 19 10 13 10 13 17 13 17 21 17 21 3119 09 19 09 19 55 10 13 19 55 60 67 10 13 17 21 60 67 10 13 17 21 13 17 21 13 17 21 17 21 3133 04 19 3133 04 10 3133 06 19 3133 06 10 3133 06 13 3133 08 10 3133 08 13 3133 08 17 3133 10 13 3133 10 17 3133 10 21 3133 12 13 3133 12 17 3133 12 21 C 4 4 6 6 8 8 8 10 10 10 12 12 12 14 14 R1/8 R1/4 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R3/8 R1/2 3175 04 04 06 06 08 08 08 10 10 10 12 12 12 14 14 10 13 10 13 10 13 17 13 17 21 13 17 21 17 21 3113 04 06 06 08 08 08 10 10 12 12 12 10 10 13 10 13 17 13 17 13 17 21 4 4 6 6 8 8 10 C M5x0,8 G1/8 G1/8 G1/4 G1/4 G3/8 G3/8 3119 3119 3119 3119 3119 3119 3119 04 04 06 06 08 08 10 19 10 10 13 13 17 17 C R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R3/8 R1/2 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 3175 04 04 04 06 06 06 06 08 08 08 08 10 10 10 10 12 12 12 14 14 10 13 17 10 13 17 21 10 13 17 21 10 13 17 21 13 17 21 17 21 45° male elbow, BSPT thread ØD C 4 6 6 8 8 8 10 10 10 12 12 12 R1/8 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 3113 3113 3113 3113 3113 3113 3113 3113 3113 3113 3113 3113 04 06 06 08 08 08 10 10 10 12 12 12 10 10 13 10 13 17 13 17 21 13 17 21 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 3199 03 03 04 04 04 04 04 06 06 06 06 06 06 06 06 08 08 08 08 08 08 10 10 10 12 12 12 14 14 09 19 09 19 55 10 13 19 55 60 67 10 13 17 21 60 67 10 13 17 21 13 17 21 13 17 21 17 21 04 04 06 06 08 08 10 19 10 10 13 13 17 17 male stud elbow, BSPP and metric thread C twin banjo, BSPP and M5 thread ØD ØD 3181 04 55 3181 06 55 male stud fitting, hexagonal, with BSPT thread 3 M3x0,5 3 M5x0,8 4 M3x0,5 4 M5x0,8 4 M7x1 4 G1/8 4 G1/4 6 M5x0,8 6 M7x1 6 M10x1 6 M12x1,5 6 G1/8 6 G1/4 6 G3/8 6 G1/2 8 M10x1 8 M12x1,5 8 G1/8 8 G1/4 8 G3/8 8 G1/2 10 G1/4 10 G3/8 10 G1/2 12 G1/4 12 G3/8 12 G1/2 14 G3/8 14 G1/2 3149 double banjo, BSPP and M5 thread M7x1 M7x1 ØD C 3018 3018 3018 3018 3018 3018 3018 3018 3018 3018 3018 C 4 6 4 4 4 6 6 6 6 8 8 8 8 10 10 10 10 12 12 12 14 14 single banjo, BSPT thread R1/8 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/4 R3/8 R1/2 ØD ØD 3199 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 3129 male stud fitting, round body, M7 thread An internal hexagon assists tightening. C M5x0,8 G1/8 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 ØD 4 6 6 8 8 8 10 10 12 12 12 C M3x0,5 M5x0,8 M5x0,8 G1/8 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G3/8 G1/2 03 03 04 04 04 04 04 06 06 06 06 06 06 06 06 08 08 08 08 08 08 10 10 10 12 12 12 14 14 extended male stud elbow, BSPT thread ØD single banjo, BSPP, M3 and M5 thread 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 3101 45° male elbow, BSPP and M5 thread ØD extended male stud elbow, BSPP, M5 and M7 thread 3181 C 3 M3x0,5 3 M5x0,8 4 M3x0,5 4 M5x0,8 4 M7x1 4 G1/8 4 G1/4 6 M5x0,8 6 M7x1 6 M10x1 6 M12x1,5 6 G1/8 6 G1/4 6 G3/8 6 G1/2 8 M10x1 8 M12x1,5 8 G1/8 8 G1/4 8 G3/8 8 G1/2 10 G1/4 10 G3/8 10 G1/2 12 G1/4 12 G3/8 12 G1/2 14 G3/8 14 G1/2 19 10 13 10 13 10 13 17 13 17 21 17 21 17 C R1/8 R1/4 R3/8 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R3/8 R1/2 male stud fitting, hexagonal, with BSPP, M3, M5 and M7 thread ØD 3114 3114 3114 3114 3114 3114 3114 3114 3114 3114 3114 3114 3114 3114 male stud elbow, BSPT thread ØD 3169 3101 4 4 6 6 8 8 10 C M5x0,8 G1/8 G1/8 G1/4 G1/4 G3/8 G3/8 3149 3149 3149 3149 3149 3149 3149 3108 male stud branch tee, BSPT thread ØD C 4 4 6 6 8 8 8 10 10 10 12 12 12 14 14 R1/8 R1/4 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R3/8 R1/2 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3108 3103 04 04 06 06 08 08 08 10 10 10 12 12 12 14 14 10 13 10 13 10 13 17 13 17 21 13 17 21 17 21 male stud run tee, BSPT thread ØD C 4 4 6 6 8 8 8 10 10 10 12 12 12 14 14 R1/8 R1/4 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R1/4 R3/8 R1/2 R3/8 R1/2 3121 ØD 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 3103 04 04 06 06 08 08 08 10 10 10 12 12 12 14 14 10 13 10 13 10 13 17 13 17 21 13 17 21 17 21 4 4 6 6 8 8 8 10 10 10 12 12 14 3131 3198 3148 3189 male stud branch tee BSPP and M5 thread ØD C 4 4 4 6 6 6 8 8 8 10 10 10 12 12 12 14 14 M5X0,8 G1/8 G1/4 M5X0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 3198 04 04 04 06 06 06 08 08 08 10 10 10 12 12 12 14 14 3193 19 10 13 19 10 13 10 13 17 13 17 21 13 17 21 17 21 "Y" piece with male BSPT thread ØD C 4 4 6 6 8 8 8 10 10 10 12 12 R1/8 R1/4 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R3/8 R1/2 3158 4 4 6 6 6 8 8 8 10 10 12 12 04 04 06 06 08 08 08 10 10 10 12 12 4 4 4 6 6 6 8 8 8 10 10 10 12 12 12 14 14 M5x0,8 G1/8 G1/4 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 G3/8 G1/2 3159 3189 3189 3189 3189 3189 3189 3189 3189 3189 3189 3189 3189 04 04 06 06 06 08 08 08 10 10 12 12 19 10 19 10 13 10 13 17 13 17 13 17 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 3193 04 04 04 06 06 06 08 08 08 10 10 10 12 12 12 14 14 19 10 13 19 10 13 10 13 17 13 17 21 13 17 21 17 21 3192 "Y" piece with male BSPP and M5 thread 4 4 4 6 6 6 8 8 8 10 10 10 12 12 10 13 10 13 10 13 17 13 17 21 17 21 C M5x0,8 G1/8 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/4 G3/8 C ØD 3148 3148 3148 3148 3148 3148 3148 3148 3148 3148 3148 3148 oscillating compact elbow, BSPP and M5 stud ØD male stud run tee BSPP and M5 thread ØD C M5x0,8 G1/8 G1/4 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G3/8 G1/2 3158 3158 3158 3158 3158 3158 3158 3158 3158 3158 3158 3158 3158 3158 04 04 04 06 06 06 08 08 08 10 10 10 12 12 19 10 13 19 10 13 10 13 17 13 17 21 17 21 3112 oscillating compact elbow, BSPT stud ØD 4 6 6 8 8 8 10 10 12 12 male BSPT threaded standpipe C R1/8 R1/4 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/2 R3/8 R1/2 R1/2 carstick® ØD C 4 4 4 6 6 8 8 8 10 10 10 12 12 14 14 M5x0,8 G1/8 G1/4 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G3/8 G1/2 G3/8 G1/2 04 06 08 10 12 00 00 00 00 00 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 3131 04 04 04 06 06 08 08 08 10 10 10 12 12 14 14 19 10 13 10 13 10 13 17 13 17 21 17 21 17 21 ØD C 4 4 6 6 8 8 8 10 10 10 12 12 12 G1/8 G1/4 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G1/4 G3/8 G1/2 3192 3192 3192 3192 3192 3192 3192 3192 3192 3192 3192 3192 3192 04 04 06 06 08 08 08 10 10 10 12 12 12 10 13 10 13 10 13 17 13 17 21 13 17 21 double "Y" piece with male BSPT thread ØD C 4 4 6 6 R1/8 R1/4 R1/8 R1/4 3112 3112 3112 3112 04 04 06 06 10 13 10 13 C R1/8 R1/8 R1/4 R1/8 R1/4 R3/8 R1/4 R3/8 R1/4 R3/8 3159 3159 3159 3159 3159 3159 3159 3159 3159 3159 04 06 06 08 08 08 10 10 12 12 10 10 13 10 13 17 13 17 13 17 3132 ØD cartridge 3100 3100 3100 3100 3100 10 13 10 13 10 13 17 13 17 21 17 21 21 female stud elbow, BSPP thread double "Y" with male BSPP thread ØD C 4 4 6 6 G1/8 G1/4 G1/8 G1/4 A free service accessible to everyone. 4 6 8 10 12 04 04 06 06 08 08 08 10 10 10 12 12 14 male parallel and M5 threaded standpipe carstick® 3100 3121 3121 3121 3121 3121 3121 3121 3121 3121 3121 3121 3121 3121 Download CAD drawings of all LF 3000® models from 3132 3132 3132 3132 04 04 06 06 10 13 10 13 banjo bodies for modular construction 3538 3527 single banjo bodies ØD C 3 4 4 6 6 6 8 8 8 10 10 10 12 12 M5x0,8 M5x0,8 G1/8 M5x0,8 G1/8 G1/4 G1/8 G1/4 G3/8 G1/4 G3/8 G1/2 G3/8 G1/2 3539 3538 3538 3538 3538 3538 3538 3538 3538 3538 3538 3538 3538 3538 3538 03 04 04 06 06 06 08 08 08 10 10 10 12 12 19 19 10 19 10 13 10 13 17 13 17 21 17 21 3528 double banjo bodies ØD C 4 4 6 6 8 8 10 M5X0,8 G1/8 G1/8 G1/4 G1/4 G3/8 G3/8 3549 twin banjo bodies Ø D 3539 3539 3539 3539 3539 3539 3539 04 04 06 06 08 08 10 19 10 10 13 13 17 17 stacking banjo for 2 body high modules BSPP and M5 thread 3529 C M5x0,8 G1/8 G1/4 G3/8 single banjo bolts, BSPP and M5 thread 3528 3528 3528 3528 00 00 00 00 C 4 M5x0,8 4 G1/8 4 G1/4 6 G1/8 6 G1/4 6 G3/8 8 G1/4 8 G3/8 10 G3/8 3549 3549 3549 3549 3549 3549 3549 3549 3549 04 04 04 06 06 06 08 08 10 19 10 13 10 13 17 13 17 17 stacking banjo for 3 body high modules BSPP thread 19 10 13 17 C G1/8 G1/4 G3/8 3529 00 10 3529 00 13 3529 00 17 C M5x0,8 G1/8 G1/4 G3/8 G1/2 3527 3527 3527 3527 3527 00 00 00 00 00 19 10 13 17 21 3524 female threaded banjo bolts, BSPP and M5 thread C1 C1 C2 M5x0,8 M5x0,8 3524 00 19 G1/8 G1/8 3524 00 10 G1/4 G1/4 3524 00 13 G3/8 G3/8 3524 00 17 G1/2 G1/2 3524 00 21 C2 multiple fittings and manifolds 3306 unequal multiple elbow, with fixing holes ØD2 manifold with LF 3000 push-in connection ØD1 ØD2 6 8 8 10 ØD1 10 3107 3310 4 4 6 6 8 3306 3306 3306 3306 3306 06 08 08 10 10 04 04 06 06 08 equal cross 3107 4 6 8 3107 04 00 3107 06 00 3107 08 00 C 4 6 8 10 12 G1/4 G1/4 G3/8 G1/2 G1/2 ØD1 04 06 08 10 12 13 13 17 21 21 3107 6 8 6 8 8 10 ØD1 10 ØD2 3107 04 06 3107 06 08 ØD1 ØD1 4 4 6 6 8 3304 3304 3304 3304 3304 06 08 08 10 10 04 04 06 06 08 unequal cross ØD2 ØD1 ØD2 4 6 unequal multiple tee, with fixing holes ØD1 ØD2 3310 3310 3310 3310 3310 unequal cross ØD2 ØD ØD 3304 ØD1 ØD2 4 6 6 8 3107 06 04 3107 08 06 ØD1 ØD2 ØD2 modular plug-in connectors 3300 modular plug-in connectors 3381 ØD 3300 04 00 3300 06 00 3300 08 00 multi-connector male screw body o.d. tube 4 4 4 4 6 6 6 8 3379 ØD 4 6 8 3320 DIN-rail connector for 3 tubes in line 2 4 7 12 2 4 7 2 04 04 04 04 06 06 06 08 00 00 00 00 00 00 00 00 02 04 07 12 02 04 07 02 3381 04 00 3381 06 00 3381 08 00 multi-connector female screw body o.d. tube 3320 3320 3320 3320 3320 3320 3320 3320 ØD 4 6 8 3321 number of outlets 4 4 4 4 6 6 6 8 DIN-rail connector for 2 tubes 3329 number of outlets 2 4 7 12 2 4 7 2 4 6 8 3379 04 00 3379 06 00 3379 08 00 multi-connector screw cap number of outlets 3321 3321 3321 3321 3321 3321 3321 3321 04 04 04 04 06 06 06 08 00 00 00 00 00 00 00 00 02 04 07 12 02 04 07 02 2 4-7 12 3329 00 01 3329 00 02 3329 00 03 pneumatic push-in fittings ® system LF 3000 accessories 0178 reducer male to female, BSPP and M5 C1 0179 increaser male to female, BSPP and M12 C2 M7x1 M5x0,8 G1/8 M5x0,8 G1/4 G1/8 G3/8 G1/8 G3/8 G1/4 G1/2 G1/4 G1/2 G3/8 G3/4 G1/2 0178 0178 0178 0178 0178 0178 0178 0178 55 10 13 17 17 21 21 27 19 19 10 10 13 13 17 21 3000 C1 C2 M12x1,5 G1/8 G1/4 G3/8 G1/4 G1/4 G3/8 G1/2 C 0179 0179 0179 0179 67 10 13 17 13 13 17 21 M5x0,8 M7x1 G1/8 G1/4 G3/8 G1/2 0222 0222 0222 0222 0222 0222 19 55 10 13 17 21 00 00 00 00 00 00 Clip Clip Clip Clip Clip Clip 04 06 08 10 12 14 00 00 00 00 00 00 disconnection tool ØD 4 6 8 10 12 14 3110 threaded plug, BSPP and M5 0222 3000 3000 3000 3000 3000 3000 70 70 70 70 70 70 04 06 08 10 12 14 clip strips for tubes Clip ØD 4 6 8 10 12 14 coloured release button covers Ø D 4 6 8 10 12 14 3110 3110 3110 3110 3110 3110 04 06 08 10 12 14 00 00 00 00 00 00 3110 3110 3110 3110 3110 3110 04 06 08 10 12 14 02 02 02 02 02 02 3110 3110 3110 3110 3110 3110 04 06 08 10 12 14 03 03 03 03 03 03 3110 3110 3110 3110 3110 3110 04 06 08 10 12 14 04 04 04 04 04 04 3110 3110 3110 3110 3110 3110 04 06 08 10 12 14 05 05 05 05 05 05 3 mm push-in fittings 3281 3299 3229 male stud fitting, M3 and M5 thread ØD C 3 3 M3x0,5 M5x0,8 C 3 3 M3x0,5 M5x0,8 C 3 3 M3x0,5 M5x0,8 3202 equal elbow ØD 3 3298 3299 03 09 3299 03 19 extended male stud elbow, M3 and M5 thread ØD tube/tube connector ØD 3281 03 09 3281 03 19 compact male stud elbow, M3 and M5 thread ØD 3206 3293 3229 03 09 3229 03 19 3218 3206 03 00 male stud branch tee, M3 and M5 thread ØD C 3 3 M3x0,5 M5x0,8 C 3 3 M3x0,5 M5x0,8 C 3 3 M3x0,5 M5x0,8 3202 03 00 equal tee ØD 3 3266 3293 03 09 3293 03 19 single banjo, M3 and M5 thread ØD 3204 3298 03 09 3298 03 19 male stud run tee, M3 and M5 thread ØD 3 3226 3204 03 00 4 mm to 3 mm reducer ØD1 ØD2 3 4 3266 03 04 blanking plug ØD 3218 03 09 3218 03 19 3 3226 03 00 plug-in fittings 3188 plug-in equal and unequal compact tee with plastic tailpiece ØD1 ØD1 ØD2 4 6 8 10 12 4 6 8 10 12 3188 3188 3188 3188 3188 04 06 08 10 12 00 00 00 00 00 4 6 8 10 6 8 10 12 3188 3188 3188 3188 04 06 08 10 06 08 10 12 3180 45° equal elbow with plastic tailpiece ØD1 ØD2 ØD1 ØD2 4 6 8 10 12 4 6 8 10 12 3180 3180 3180 3180 3180 04 06 08 10 12 3182 00 00 00 00 00 ØD1 ØD1 ØD2 3184 extended equal and unequal elbow with plastic tailpiece ØD1 3183 plug-in equal and unequal run tee with plastic tailpiece ØD1 ØD1 ØD2 4 6 8 10 12 4 6 8 10 12 3183 3183 3183 3183 3183 04 06 08 10 12 00 00 00 00 00 4 6 8 10 6 8 10 12 3183 3183 3183 3183 04 06 08 10 06 08 10 12 ØD2 ØD2 4 6 8 10 ØD1 12 4 6 8 10 12 3184 3184 3184 3184 3184 04 06 08 10 12 00 00 00 00 00 4 6 8 10 6 8 10 12 3184 3184 3184 3184 04 06 08 10 06 08 10 12 ØD2 plug-in equal and unequal compact elbow with plastic tailpiece ØD1 ØD2 4 6 8 10 12 4 6 8 10 12 3182 3182 3182 3182 3182 04 06 08 10 12 00 00 00 00 00 4 6 6 8 10 6 4 8 10 12 3182 3182 3182 3182 3182 04 06 06 08 10 06 04 08 10 12 3126 3126 3126 3126 3126 3126 3126 03 04 06 08 10 12 14 00 00 00 00 00 00 00 ØD1 ØD2 plug-in fittings and accessories 3142 plug-in equal and unequal single "Y" piece ØD2 ØD1 3143 3166 ØD1 ØD2 4 6 8 10 12 4 6 8 10 12 3142 3142 3142 3142 3142 04 06 08 10 12 00 00 00 00 00 4 6 8 10 6 8 10 12 3142 3142 3142 3142 04 06 08 10 06 08 10 12 ØD1 4 4 6 3143 04 06 3143 04 08 3143 06 08 ØD1 3168 ØD2 ØD2 6 8 8 ØD1 3120 3 4 4 4 6 6 6 6 ØD1 8 8 8 10 10 12 ØD1 ØD2 6 8 10 12 4 6 8 10 3168 3168 3168 3168 06 08 10 12 04 06 08 10 ØD2 4 6 8 10 8 10 12 14 10 12 14 12 14 14 blanking plug ØD 3166 3166 3166 3166 3166 3166 3166 3166 3166 3166 3166 3166 3166 3166 03 04 04 04 06 06 06 06 08 08 08 10 10 12 04 06 08 10 08 10 12 14 10 12 14 12 14 14 3 4 6 8 10 12 14 3122 ØD 3120 3120 3120 3120 3120 3120 04 06 08 10 12 14 00 00 00 00 00 00 barbed connector for unequal tube ØD1 ØD1 double male stem connector - plastic 4 6 8 10 12 14 increaser ØD2 3126 ØD1 plug-in multiple "Y" piece ØD2 reducer 4 4 6 8 8 10 10 ØD2 12 12 12 14 14 ØD2 5 3,2 5 6,3 8 6,3 8 8 10 12,5 12,5 14 3122 3122 3122 3122 3122 3122 3122 3122 3122 3122 3122 3122 04 04 06 08 08 10 10 12 12 12 14 14 05 53 05 56 08 56 08 08 10 62 62 14 www.legris.com Connection solutions for industrial fluids Our low pressure catalogue is available upon request.
3140 06 08 价格&库存
很抱歉,暂时无法提供与“3140 06 08”相匹配的价格&库存,您可以联系我们找货
