G9225S05B2-FSR
G9225S05B2-FSR
    MECHATRONICSFANGROUP(机电一体化)
    风扇 管轴式 5VDC 方形 - 92mm 长 x 92mm 高 滚珠 3 引线
G9225S05B2-FSR 数据手册
LOW NOISE 3.62 ±0.02 (92.0 ±0.5) 0.98 ±0.02 (25 ±0.5) 3.25 ±0.02 (82.5 ±0.5) 0.12 (3) 6.0 X 0.16 (4) STATIC PRESSURE - MM OF WATER DC AXIAL FANS G9225-G series E 5.0 H 4.0 M L 3.0 S 2.0 1.0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 AIR FLOW (M3/MIN) 4x Ø 0.17 (Ø 4.4) (92 x 92 x 25 mm) 3.62 x 3.62 x 0.98 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing or sleeve Rated Voltage V Speed Current mA 5 12 24 RPM Air Volume Max. Static Pressure (H2 0) M³/Min. CFM MM INCH Sound Noise Weight dbA g AWG 24, UL1007 lead wires G9225S-G 5/12/24 220 90 60 1,200 0.67 24 0.70 0.03 19 86 Frame: flanged G9225L-G 5/12/24 340 140 90 1,600 0.89 31 1.20 0.05 21 86 Protection: thermal G9225M-G 5/12/24 480 200 120 2,000 1.13 40 1.80 0.07 23 86 Options: tachometer output or locked rotor alarm signal; encapsulated motor; PWM speed control G9225H-G 12/24 - 280 160 2,400 1.35 48 2.50 0.10 26 86 G9225E-G 12/24 - 370 200 2,800 1.61 57 3.40 0.13 30 86 G9225X-G 12/24 - 490 290 3,200 1.87 66 4.38 0.17 34 86 Connection: w w w.mechatronic s.com 12.15.14 Model No. E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 Cooling Simplified
G9225S05B2-FSR 价格&库存
很抱歉,暂时无法提供与“G9225S05B2-FSR”相匹配的价格&库存,您可以联系我们找货
