G6015E24B-RGR-CC-GB
G6015E24B-RGR-CC-GB
    MECHATRONICSFANGROUP(机电一体化)
    风扇 管轴式 24VDC 方形 - 60mm 长 x 60mm 高 滚珠 21.0 CFM(0.588m³/min) 2 引线
G6015E24B-RGR-CC-GB 数据手册
2.36 ±0.02 (60 ±0.5) .60 ±0.01 (15.3 ±0.3) 1.97 ±0.02 (50 ±0.5) 8.0 STATIC PRESSURE - MM OF WATER DC AXIAL FANS G6015-G series 0.16 (4) X E 6.0 H M L 4.0 S 2.0 0 0.20 (60 x 60 x 15 mm) 0.40 0.60 0.80 AIR FLOW (M3/MIN) 4x Ø 0.18 ±0.01 (Ø 4.5 ±0.3) 2.36 x 2.36 x 0.60 inches Features: high static pressure impeller design Construction: UL94V-0 PBT impeller & frame Rated Voltage Speed Current mA V 5 12 24 RPM G6015S-G 5/12 90 70 - 2,800 Bearing option: ball bearing G6015L-G 5/12/24 130 90 65 Connection: AWG 26, UL1007 lead wires G6015M-G 5/12/24 220 110 75 Frame: ribbed G6015H-G 5/12/24 280 130 Protection: thermal G6015E-G 5/12/24 350 G6015X-G 12/24 - Options: tachometer output or locked rotor alarm signal; encapsulated motor; PWM speed control w w w.mechatronic s.com 12.15.14 Model No. E - mail: S ales @ M echatronic s.com Fa x : 425 -2 2 2- 515 5 Air Volume Max. Static Pressure (H2 0) Weight dbA g 21 26 M³/Min. CFM MM 0.32 11.0 1.94 0.08 3,400 0.39 14.0 2.96 0.12 25 26 4,000 0.46 16.0 3.78 0.15 28 26 95 4,600 0.54 19.0 5.00 0.20 30 26 180 110 5,200 0.60 21.0 6.12 0.24 32 26 230 130 5,800 0.68 24.0 7.45 0.29 35 26 Tel: 425 -2 2 2- 5 9 0 0 800-453-4569 INCH Sound Noise Cooling Simplified
G6015E24B-RGR-CC-GB 价格&库存
很抱歉,暂时无法提供与“G6015E24B-RGR-CC-GB”相匹配的价格&库存,您可以联系我们找货
G6015E24B-RGR-CC-GB
  • 1+168.292121+21.86030
  • 10+138.3194810+17.96700
  • 25+126.9084725+16.48477
  • 50+118.6638650+15.41384
  • 100+110.83721100+14.39719
  • 300+103.22308300+13.40816
库存:1
