1192A G7X500
1192A G7X500
    BELDEN
    4 #24 PE SH PVC BLU MTT
1192A G7X500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1192A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (42x40) high-conductivity bare copper conductors, polyethylene insulation, tinned copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 24 42x40 Dia. (in.) SBC - Soft Bare Copper .024 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PE - Polyethylene .016 .056 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Cabling Color Code Chart: Number Color 1 Blue 2 White 3 Blue w/White Stripe 4 White w/Blue Stripe Overall Nominal Diameter: 0.245 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 33 lbs/1000 ft. Max. Recommended Pulling Tension: 21 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1192A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 40 Nom. Inductance: Inductance (µH/ft) .21 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 39.2 Nom. Cap. Between Cond. in a Quad Config.: Capacitance (pF/ft) 57.4 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 26.6 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 7.1 Max. Operating Voltage - UL: Voltage 100 V RMS Max. Operating Voltage - Other: Voltage Description 18.0 kV Nom. breakdown voltage between conductors 16.9 kV Nom. breakdown voltage conductors to shield Max. Recommended Current: Current 2.9 Amps per conductor @ 25°C Other Electrical Characteristic 1: 2/c 21 AWG equivalent DCR when connected to a 3-pin XLR Notes (Overall) Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one conductor, and similarly the two white wires (or remaining wires) are connected together to form the second conductor. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1192A B59N1000 1,000 FT 36.000 LB BLACK, MATTE C 4 #24 PE SH PVC BLK MTT 1192A B59100 100 FT 4.100 LB BLACK, MATTE 1192A B591000 1,000 FT 36.000 LB BLACK, MATTE C 4 #24 PE SH PVC BLK MTT 1192A B59500 500 FT 18.000 LB BLACK, MATTE C 4 #24 PE SH PVC BLK MTT 1192A G7V1000 1,000 FT 36.000 LB RED, MATTE C 4 #24 PE SH PVC RED MTT 1192A G7WN1000 1,000 FT 36.000 LB GREEN, MATTE C 4 #24 PE SH PVC GRN MTT 1192A G7W1000 1,000 FT 36.000 LB GREEN, MATTE C 4 #24 PE SH PVC GRN MTT 1192A G7X1000 1,000 FT 36.000 LB BLUE, MATTE C 4 #24 PE SH PVC BLU MTT 1192A G7X500 500 FT 18.000 LB BLUE, MATTE 4 #24 PE SH PVC BLU MTT 1192A G8CN1000 1,000 FT 36.000 LB PURPLE, MATTE 4 #24 PE SH PVC PUR MTT 1192A G8C1000 1,000 FT 36.000 LB PURPLE, MATTE 4 #24 PE SH PVC PUR MTT 1192A G8M1000 1,000 FT 36.000 LB YELLOW, MATTE 1192A U901000 1,000 FT 36.000 LB GRAY, MATTE 4 #24 PE SH PVC BLK MTT 4 #24 PE SH PVC YEL MTT C 4 #24 PE SH PVC GRY MTT Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1192A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable Revision Number: 1 Revision Date: 08-01-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1192A G7X500 价格&库存
很抱歉,暂时无法提供与“1192A G7X500”相匹配的价格&库存,您可以联系我们找货
