1319SB 0101000
1319SB 0101000
    BELDEN
    4 PR #23 PP FRNHPO FRNHPO
1319SB 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1319SB Multi-Conductor - Category 6 UTP - ABS Type Approved For more Information please call 1-800-Belden1 General Description: 23 AWG solid bare copper conductors, polyolefin insulation, LSZH jacket with ripcord, descending footage marking every two feet. Usage (Overall) Suitable Applications: Shipboard, Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, Cat 6, ABS Type Approval, WI-FI, Wireless LAN, Outdoor Antenna, Radio, Broadband Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material Dia. (in.) PO - Polyolefin 0.041 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) LSZH - Low Smoke Zero Halogen 0.239 Inner Jacket Ripcord: Yes Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material LSZH - Low Smoke Zero Halogen Outer Jacket Ripcord: No Overall Cable Overall Cabling Fillers: Rod Center Member Overall Nominal Diameter: 0.293 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 42 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG-LS Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1319SB Multi-Conductor - Category 6 UTP - ABS Type Approved NEC/(UL) Specification: CMG-LS CEC/C(UL) Specification: CMG-LS EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: Std. 45 clause 23 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 08/08/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 6, UL 444, ABS Type Approval Certificate 06-HS184641G Flame Test UL Flame Test: UL1685 FT4 Loading, Limited Smoke CSA Flame Test: FT4, Limited Smoke IEC Flame Test: 60332-1, 60332-3-22 (Category A) IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 537 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 8.2 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 5 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 74.3 72.3 72.3 70.3 20.0 na 4 3.8 65.3 63.3 61.5 59.5 23.0 na 8 5.3 60.8 58.8 55.4 53.4 24.5 na Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1319SB Multi-Conductor - Category 6 UTP - ABS Type Approved 10 6.0 59.3 57.3 53.3 51.3 25.0 na 16 7.6 56.2 54.3 48.7 46.7 25.0 na 20 8.5 54.8 52.8 46.3 44.3 25.0 na 25 9.5 53.3 51.3 43.8 41.8 24.3 na 31.25 10.7 51.9 49.9 41.2 39.2 23.6 na 62.5 15.4 47.4 45.4 32.0 30.0 21.5 na 100 19.8 44.3 42.3 24.5 22.5 20.1 na 155 25.2 41.5 39.5 16.3 14.3 18.8 na 200 29.0 39.8 37.8 10.8 8.8 18.0 na 250 32.8 38.3 36.3 5.5 3.5 17.3 na Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 67.8 64.8 4 100 ± 15 100 ± 15 55.8 52.7 8 100 ± 15 100 ± 15 49.7 46.7 10 100 ± 15 100 ± 15 47.8 44.8 16 100 ± 15 100 ± 15 43.7 40.7 20 100 ± 15 100 ± 15 41.8 38.8 25 100 ± 15 100 ± 15 39.8 36.8 31.25 100 ± 15 100 ± 15 37.9 34.9 62.5 100 ± 15 100 ± 15 31.9 28.9 100 100 ± 15 100 ± 15 27.8 24.8 155 100 ± 22 100 ± 15 23.9 20.9 200 100 ± 22 100 ± 15 21.8 18.8 250 100 ± 32 100 ± 15 19.8 16.8 Notes (Overall) Notes: RJ-45 Compatible. Jacket marked with descending footage at 2 ft. intervals. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1319SB 0101000 1,000 FT 46.000 LB BLACK C 4 PR #23 PP FRNHPO FRNHPO 1319SB 0105000 5,000 FT 235.000 LB BLACK 4 PR #23 PP FRNHPO FRNHPO Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 01-08-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 02-01-2017
1319SB 0101000 价格&库存
很抱歉,暂时无法提供与“1319SB 0101000”相匹配的价格&库存,您可以联系我们找货
