1505DNH.00500
1505DNH.00500
    BELDEN
    BELDEN - 1505DNH.00500 - Coaxial Cable, RG59U, 20 AWG, 75 ohm, 1640 ft, 500 m
1505DNH.00500 数据手册
Part Number: 1505DNH COAX RG59/U LSZH HDTV PRECISION VIDEO Product Description COAX [0.8/3.7] RG59/U LSZH HDTV CLASSICS PRO Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Dca Suitable Applications: Low loss HDTV/SDI Digital coax used in analog and digital video circuits and high quality applications; The outer conductor is designed for high screening attenuation and low transfer impedance; The cable is suitable for indoor and outdoor use Physical Characteristics (Overall) Conductor AWG Stranding 20 Solid Material Nominal Diameter Diameter +/- Tolerance No. of Coax BC - Bare Copper 0.81 mm Conductor Count: 0.03 mm 1 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Dielectric FPE - Foamed Polyethylene 3.68 mm 0.15 mm Outer Shield Material Type Layer Material Tape, bonded to dielectric 1 Aluminum/Polyester/Aluminum Braid 2 TC - Tinned Copper Tape, (L-folded) bonded to sheath 3 Aluminum/Polyester Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance LSZH / FRNC 5.92 mm 0.2 mm Construction and Dimensions Min Elongation at Breakof Jacket: 125 % Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 32 Ohm/km 12 Ohm/km Capacitance Nom. Capacitance Capacitance Tolerance 53 pF/m 2 pF/m Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance Coverage [%] Min. Overlap Nominal Diameter Coverage +/- Tolerance 2 mm 80 % 4.4 mm 2 mm 5% 75 Ohm 3 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 1 dB/100m 3.6 MHz 2 dB/100m 10 MHz 3 dB/100m 71.5 MHz 6.9 dB/100m 135 MHz 8.9 dB/100m 270 MHz 12.5 dB/100m 360 MHz 14.4 dB/100m 540 MHz 18.1 dB/100m 720 MHz 21.0 dB/100m 750 MHz 21.3 dB/100m 1000 MHz 24.9 dB/100m 1500 MHz 31.2 dB/100m 2250 MHz 39.0 dB/100m 3000 MHz 45.9 dB/100m 4500 MHz 57.4 dB/100m Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] Velocity of Propagation Tolerance 400 ns/ft 83 % 2% High Freq Frequency [MHz] Min. RL (Return Loss) [dB] 5 - 1600 MHz 23 dB 1600 - 4500 MHz 21 dB High Freq Table Note: In each frequency band, 1 peak value up to 4 dB lower is allowed Screening Frequency [MHz] Min. Screening Attenuation 30 - 1000 MHz 95 dB 1000 - 2000 MHz 85 dB 2000 - 3000 MHz 75 dB 3000 - 4500 MHz 65 dB Screening Class: A+ Transfer Impedance Transfer Impedance Max. 2.5 mOhm/m Voltage Voltage Test Dielectric 2.0 kV DC Temperature Range Installation Temp Range: -5°C To +50°C Storage Temp Range: -30°C To +70°C Operating Temp Range: -30°C To +70°C Mechanical Characteristics Max Recommended Pulling Tension: 200 N Min Bend Radius (W/o Pulling Strength): 60 mm Standards CPR Euroclass: Dca-s1,d1,a1 CENELEC Compliance: EN 50117-1 RG Type: 59/U Type Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2005-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 and IEC 60332-3-24 Other Flammability: CEI 20-22-3 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # Color Length 1505DNH.03500 Black 500 m 1505DNH.04500 Green 500 m 1505DNH.00500 Purple 500 m 1505DNH.02500 Yellow 500 m History Update and Revision: Revision Number: 0.163 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1505DNH.00500 价格&库存
很抱歉,暂时无法提供与“1505DNH.00500”相匹配的价格&库存,您可以联系我们找货
