1590A D151000
1590A D151000
    BELDEN
    CAT5E 2PR U/UTP CMP REEL
1590A D151000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1590A Multi-Conductor - Category 5e Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e (200MHz), 2-Pair, U/UTP-Unshielded, Plenum-CMP, Premise Horizontal Cable, 24 AWG solid bare copper conductors FEP insulation, Ripcord, Flamarrest® jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422 Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 24 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.165 Outer Jacket Ripcord: Yes Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 21 lbs/1000 ft. Max. Recommended Pulling Tension: 13 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 1.700 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP, UL444 CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1590A Multi-Conductor - Category 5e Nonbonded-Pair Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: 568-B.2 Category 5e Other Specification: NEMA WC-63.1 Category 5e, UL verified to Category 5e Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT4, FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 1588A, 1588R Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 14 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 72 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 5 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 65.3 62.3 63.0 60.3 20.0 23.0 4 4.1 56.3 53.3 51.0 49.2 23.0 23.0 8 5.8 51.8 48.8 46.0 43.0 24.5 24.5 10 6.5 50.3 47.3 43.0 40.8 25.0 25.0 16 8.2 47.3 44.3 39.0 36.0 25.0 25.0 20 9.3 45.8 42.8 36.5 33.5 25.0 25.0 25 10.4 44.3 41.3 33.9 30.9 24.3 24.3 31.25 11.7 42.9 39.9 31.0 28.2 23.6 23.6 62.5 17.0 38.4 35.4 22.0 19.0 21.5 21.5 100 22.0 35.3 32.3 14.0 10.3 20.1 20.1 155 28.1 32.5 29.5 4.4 1.4 15.8 200 32.0 30.8 27.8 4.0 1.0 15.0 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 63.8 60.8 4 100 ± 15 100 ± 15 51.7 48.7 8 100 ± 15 100 ± 15 45.7 42.7 10 100 ± 15 100 ± 15 43.8 40.8 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1590A Multi-Conductor - Category 5e Nonbonded-Pair Cable 16 100 ± 15 100 ± 15 39.7 36.7 20 100 ± 15 100 ± 15 37.7 34.7 25 100 ± 15 100 ± 15 35.8 32.8 31.25 100 ± 15 100 ± 15 33.9 30.9 62.5 100 ± 15 100 ± 15 27.8 24.9 100 100 ± 15 100 ± 15 23.8 20.8 155 100 ± 25 100 ± 15 19.9 16.9 200 100 ± 25 100 ± 15 17.7 14.7 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Third party verified to TIA/EIA-568-B.2, Category 5e. Put Ups and Colors: Item # Putup Ship Weight Color 1590A D151000 1,000 FT 16.000 LB BLUE 1590A 8771000 1,000 FT 16.000 LB NATURAL Notes Item Desc CAT5E 2PR U/UTP CMP REEL C CAT5E 2PR U/UTP CMP REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-06-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 02-01-2017
1590A D151000
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
1590A D151000 价格&库存
很抱歉,暂时无法提供与“1590A D151000”相匹配的价格&库存,您可以联系我们找货
