1594A-U1000-8
1594A-U1000-8
    BELDEN
    BELDEN - 1594A-U1000-8 - 4 PAIR UTP (UNSHIELDED TWISTED PAIR) CAB
1594A-U1000-8 数据手册
Part Number: 1594A CAT5e Horizontal, 4pr, UTP, PVC Jkt, CMR/CMX Outdoor Product Description CAT5e (200MHz), 4-Pair, U/UTP-unshielded, Riser-CMR, CMX Outdoor, Premise Horizontal cable, 24 AWG solid bare copper conductors, polyolefin insulation, ripcord, UV resistant PVC jacket Technical Specifications Product Overview Environmental Space: Indoor/Outdoor Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Outdoor Physical Characteristics (Overall) Conductor AWG Stranding 24 Solid Material No. of Pairs BC - Bare Copper 4 Total Number of Conductors: 8 Insulation Material PO - Polyolefin Color Chart Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Outer Shield Material Material N/A Outer Jacket Material Material Nominal Diameter Ripcord PVC - Polyvinyl Chloride 0.220 in Yes Electrical Characteristics Capacitance Max. Capacitance Unbalance Nom.Mutual Capacitance 330 pF/100m Shielding: 15 pF/ft UTP - Unshielded Construction and Dimensions Total Number of Pairs: 4 Conductor DCR Max. Conductor DCR Max. DCR Unbalance 9.38 Ohm/100m 3% Delay Max. Delay Max. Delay Skew Nominal Velocity of Propagation (VP) [%] @ 100 MHz 537.6 ns/100m 45 ns/100m 68 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) Min. NEXT [dB] Min. PSNEXT [dB] Min. ACR [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL Max./Min. Input (Return Impedance Loss) [dB] (unFitted) Max./Min. Fitted Impedance 1 MHz 2.0 dB/100m 65.3 dB 62.3 dB 63.3 dB 60.3 dB 63.8 dB 60.8 dB 20.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 4 MHz 4.1 dB/100m 56.3 dB 53.3 dB 52.2 dB 49.2 dB 51.7 dB 48.7 dB 23.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 8 MHz 5.8 dB/100m 51.8 dB 48.8 dB 46.0 dB 43.0 dB 45.7 dB 42.7 dB 24.5 dB 100 ± 15 Ohm 100 ± 15 Ohm 10 MHz 6.5 dB/100m 50.3 dB 47.3 dB 43.8 dB 40.8 dB 43.8 dB 40.8 dB 25.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 16 MHz 8.2 dB/100m 47.3 dB 44.2 dB 39.0 dB 36.0 dB 39.7 dB 36.7 dB 25.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 20 MHz 9.3 dB/100m 45.8 dB 42.8 dB 36.5 dB 33.5 dB 37.7 dB 34.7 dB 25.0 dB 100 ± 15 Ohm 100 ± 15 Ohm 25 MHz 10.4 dB/100m 44.3 dB 41.3 dB 33.9 dB 30.9 dB 35.8 dB 32.8 dB 24.3 dB 100 ± 15 Ohm 100 ± 15 Ohm 31.25 MHz 11.7 dB/100m 42.9 dB 39.9 dB 31.2 dB 28.2 dB 33.9 dB 30.9 dB 23.6 dB 100 ± 15 Ohm 100 ± 15 Ohm 62.5 MHz 17.0 dB/100m 38.4 dB 35.4 dB 21.4 dB 18.4 dB 27.8 dB 24.8 dB 21.5 dB 100 ± 15 Ohm 100 ± 15 Ohm 100 MHz 22.0 dB/100m 35.3 dB 32.3 dB 13.3 dB 10.3 dB 23.8 dB 20.8 dB 20.1 dB 100 ± 15 Ohm 100 ± 15 Ohm 155 MHz 28.1 dB/100m 32.5 dB 29.4 dB 4.4 dB 1.4 dB 19.9 dB 16.9 dB 15.8 dB 100 ± 25 Ohm 100 ± 15 Ohm 200 MHz 32.4 dB/100m 30.8 dB 27.8 dB 17.7 dB 14.7 dB 15.0 dB 100 ± 25 Ohm 100 ± 15 Ohm Voltage UL Voltage Rating 300V RMS Cold Bend Test: -40°C Compliance Per UL 1581 Applicable Standards & Environmental Programs CEC/C(UL) Specification: CMR-CMX OUTDOOR EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: Yes Third Party Performance Verification: Category 5e EU CE Mark: Yes EU REACH SVHC Compliance (yyyy-mm-dd): 2017-07-10 EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CPR Euroclass: Eca CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: ANSI/TIA-568-C.2 Category 5e Other Specification: Outdoor Use ANSI/ICEA S-56-434, Broadband Outdoor Use ANSI/ICEA S-99-689, Indoor/Outdoor Use ANSI/ICEA S-100-685 Patent: http://www.belden.com/p Standards ISO/IEC Compliance: 11801 ed 2.2 (2011) Class D ANSI/TIA Category: Category 5e ANSI Compliance: S-90-661-2012 Category 5e, ANSI/NEMA WC-63.1 Category 5e IEEE Specification: POE per 802.3af & POE+ per 802.3at-2009 NEC/(UL) Specification: CMR-CMX OUTDOOR Flame Test ISO/IEC Flammability: 60332-1 UL Flammability: UL 1666 Riser Safety UL Voltage Rating: 300 V RMS Suitability Suitability - Aerial: Yes, when supported with messenger wire Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Non-Halogenated: No Suitability - Oil Resistance: Yes Suitability - Outdoor: Yes Suitability - Sunlight Resistance: Yes Mechanical Characteristics Storage Temp Range: -40°C To +75°C Installation Temp Range: -20°C To +75°C Operating Temp Range: -40°C To +75°C Bulk Cable Weight: 23(lbs/1000ft) Max Recommended Pulling Tension: 25(lbs) Min Bend Radius/Minor Axis: 1.0(in) Min Bend Radius/Installation: 2.25(in) Temperature Range UL Temp Rating: +90°C Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1585A Part Number Non-Plenum Number: 1583A History Variants Item # 1594A 008U1000 Color GRAY 1594A 1GFU1000 Ivory 1594A 009U1000 WHITE © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be incompliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be incompliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1594A-U1000-8 价格&库存
很抱歉,暂时无法提供与“1594A-U1000-8”相匹配的价格&库存,您可以联系我们找货
