1804A U4F500
1804A U4F500
    BELDEN
    4 #28 STR PP SHLD PVC
1804A U4F500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1804A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 28 AWG stranded (19x40) high-conductivity silver- plated copper alloy conductors, polypropylene insulation, tinned copper braid shield (80% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 28 19x40 Dia. (in.) High Conductivity SPCA - Silver Plated Copper Alloy .015 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PP - Polypropylene 0.030 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 80.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Cabling Color Code Chart: Number Color 1 Blue 2 White 3 Blue w/White Stripe 4 White w/Blue Stripe Overall Nominal Diameter: 0.115 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 9 lbs/1000 ft. Max. Recommended Pulling Tension: 24 lbs. Min. Bend Radius/Minor Axis: 1.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU CE Mark: Yes EU Directive 2002/95/EC (RoHS): No Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 40 Nom. Inductance: Inductance (µH/ft) .21 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 40 Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1804A Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable Nom. Cap. Between Cond. in a Quad Config.: Capacitance (pF/ft) 60 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 65 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Max. Operating Voltage - UL: Voltage 100 V RMS Max. Recommended Current: Current 1.45 Amps per conductor @ 25°C Other Electrical Characteristic 1: 2/c 25 AWG equivalent DCR when connected to a 3-pin XLR. Notes (Overall) Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one conductor, and similarly the two white wires (or remaining wires) are connected together to form the second conductor. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1804A G8M500 500 FT 5.000 LB YELLOW, MATTE F 4 #28 STR PP SHLD PVC 1804A J5C100 100 FT 1.100 LB BLACK, VIVID MATTE 1804A J5C500 500 FT 5.000 LB BLACK, VIVID MATTE F 4 #28 STR PP SHLD PVC 1804A U4F500 500 FT 5.000 LB BEIGE U4F F 4 #28 STR PP SHLD PVC 4 #28 STR PP SHLD PVC Notes: F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' Revision Number: 2 Revision Date: 10-04-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
1804A U4F500 价格&库存
很抱歉,暂时无法提供与“1804A U4F500”相匹配的价格&库存,您可以联系我们找货
