1812A G7V328
1812A G7V328
    BELDEN
    2 #24 PVC PVC SRV PVC 1=328'
1812A G7V328 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1812A Multi-Conductor - Two-Conductor, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (42x40) high-conductivity BC conductors, PVC insulation, double bare copper spiral shield (95% coverage), PVC outer jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 24 42x40 High Conductivity BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Dia. (mm) PVC - Polyvinyl Chloride 0.3048 1.1938 Inner Jacket Inner Jacket Material: Inner Jacket Material PVC - Polyvinyl Chloride Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Double Spiral Serve BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.9398 Overall Cable Overall Nominal Diameter: 5.410 mm Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 44.646 Kg/Km Max. Recommended Pulling Tension: 44.482 N Min. Bend Radius/Minor Axis: 57.150 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 2 05-02-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1812A Multi-Conductor - Two-Conductor, Low-Impedance Cable Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.643076 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 108.273 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 177.174 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 76.4473 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 17.3893 Max. Operating Voltage - Non-UL: Voltage 100 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 1812A B59N1000 1,000 FT 33.000 LB BLACK, MATTE Notes Item Desc 1812A B591000 1,000 FT 33.000 LB BLACK, MATTE 1812A B59328 328 FT 10.496 LB BLACK, MATTE 2 #24 PVC PVC SRV PVC 1812A G7VN1000 1,000 FT 33.000 LB RED, MATTE 2 #24 PVC PVC SRV PVC 1812A G7V328 328 FT 10.496 LB RED, MATTE 2 #24 PVC PVC SRV PVC 1812A G7WN1000 1,000 FT 33.000 LB GREEN, MATTE 2 #24 PVC PVC SRV PVC 1812A G7W1000 1,000 FT 33.000 LB GREEN, MATTE 2 #24 PVC PVC SRV PVC 1812A G7XN1000 1,000 FT 33.000 LB BLUE, MATTE 1812A G7X1000 1,000 FT 33.000 LB BLUE, MATTE 2 #24 PVC PVC SRV PVC C 2 #24 PVC PVC SRV PVC 2 #24 PVC PVC SRV PVC C 2 #24 PVC PVC SRV PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 08-24-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 2 of 2 05-02-2016
1812A G7V328 价格&库存
很抱歉,暂时无法提供与“1812A G7V328”相匹配的价格&库存,您可以联系我们找货
