1868ENH.00500
1868ENH.00500
    BELDEN
    BELDEN - 1868ENH.00500 - Networking Cable, Screened, Cat5e, 26 AWG
1868ENH.00500 数据手册
1868ENH Networking Cables Datatwist® cable CAT 5E F/UTP LSNH PATCH 2011-09-08 v9 Applications · Work area patch cable · Support current and future Category 5e applications, such as: 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI, ATM General standards · International standard: ISO/IEC 11801 2nd edition (2002) and ISO/IEC 11801 Amendment 2 (2010) · European standard: EN 50173-1 (2002) and EN 50173-1 Amendment 1 (2009) · U.S. Standards: ANSI/TIA/EIA 568-B.2-1 (2002) Construction & Dimensions 1 2 3 4 5 1. Conductor Material Diameter Stranded bare copper ETP AWG 26 (7x AWG 34) 2. Insulation Material Nominal diameter over insulation Polyethylene 0.95 mm 3. Cable core Pair Number of pairs Colour code pair 1 Colour code pair 2 Colour code pair 3 Colour code pair 4 2 twisted insulated conductors 4, all twisted together Black / Blue & Blue Black / Orange & Orange Black / Green & Green Black / Brown & Brown 4. Foil shielding Material Position aluminium Drain wire material Drain wire diameter Laminated Aluminium / Polyester Facing inside, in contact with drain wire Stranded tinned copper AWG 26 (7x AWG 34) 5. Jacket Material Diameter LSNH 5.4 ± 0.3 mm Electrical characteristics Reference standard: ISO/IEC 61156-6 edition 3.0 (2010) Low frequency and D.C. (at 20°C) D.C. resistance conductor Resistance unbalance: within a pair / between pairs Insulation resistance Dielectric strength conductor-conductor and conductor-screen (2 sec.) Mutual capacitance Capacitance unbalance pair to ground Nominal velocity of propagation (for information only) Delay skew (differential delay) Transfer impedance according IEC 61156-5 Coupling attenuation according IEC 61156-5 High frequency (at 20°), reference standard: ISO/IEC61156-5 TYPE 1* 4 10 16 Specification < 14.5 9 Unit % % % MPa Environmental and overall characteristics Maximum operating voltage (for all temperatures cable is intended to be used) Maximum continuous current per conductor (@25°C) Temperature rating installation Temperature rating operation Total cable weight Minimum bending radius (during operation and installation) Maximum pulling strength Burning load Smoke density acc. to IEC 61034-1/2 & EN50268-1/2; transmittance Amount of halogen acid gas acc. to IEC 60754-1/2 & EN50267-1/2; pH Amount of halogen acid gas acc. to IEC 60754-1/2 & EN50267-1/2; Conductivity Fire performance according IEC 60332-1 Specification 72 1.5 0 / 50 - 30 / 60 31 21 / 42 72 395 > 60 > 4.3 < 10 Pass Unit V D.C. A °C °C kg/km mm N kJ/m % µS/mm Belden declares this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC, 27 January 2003); this is valid for all material produced after the RoHS compliant date for this product. 3
1868ENH.00500 价格&库存
很抱歉,暂时无法提供与“1868ENH.00500”相匹配的价格&库存,您可以联系我们找货
