29502 010250
29502 010250
    BELDEN
    CABLE 4 COND 12AWG SHLD 250
29502 010250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 29502 Multi-Conductor - 1000V UL Flexible Motor Supply Cable For more Information please call 1-800-Belden1 General Description: 4-cond. (3) stranded tinned copper circuit conductors plus (1)ground wire with PVC insulation, XLP insulation, Overall Duofoil® (100% coverage) plus a tinned copper braid shield (85% coverage) , tinned copper drain wire, Sun- & oil-resistant PVC jacket. Usage (Overall) Suitable Applications: AC Motor Drives, VFD, Variable Frequency Drive Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 12 65x30 TC - Tinned Copper Total Number of Conductors: 3 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 12 Ground Wire Stranding: 65x30 Ground Wire Conductor Material: TC - Tinned Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (in.) XLP - Cross Linked Polyolefin 0.045 Insulation Resistance: 300 Megaohms/1000 ft. Insulation Color Code Chart: Number Color 1 Black and Numbered 1 2 Black and Numbered 2 3 Black and Numbered 3 4 Green/Yellow Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 85 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 12 65x30 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.073 Overall Cable Overall Nominal Diameter: 0.630 in. Mechanical Characteristics (Overall) Wet Temperature Range: -40°C To +90°C Dry Temperature Range: -40°C To +90°C Bulk Cable Weight: 250 lbs/1000 ft. Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 29502 Multi-Conductor - 1000V UL Flexible Motor Supply Cable Max. Recommended Pulling Tension: 336 lbs. Min. Bend Radius/Minor Axis: 5 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: TC-ER, Unlisted Singles, WTTC NEC Articles: 336 - ER CEC/C(UL) Specification: 600V Type CIC TC CSA Specification: 1000 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes PMSHA Specification: P-07-KA070003 Other Specification: 1000V UL Flexible Motor Supply Cable Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT4 IEEE Flame Test: 1202, IEEE 383 Vertical Tray Flame Test (70,000 BTU) Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Burial: Yes Sunlight Resistance: Yes Oil Resistance: Yes Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 71 Nom. Inductance: Inductance (µH/ft) .197 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 26 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 47 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.6 Max. Operating Voltage - UL: Voltage 1000 V RMS (Flexible Motor Supply Cable) 600 V RMS (NEC Type TC) Max. Operating Voltage - Other: Voltage Description 1000 V RMS CSA AWM I/II A/B Max. Recommended Current: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 29502 Multi-Conductor - 1000V UL Flexible Motor Supply Cable Current 30 Amps per conductor @ 30°C (per NEC) Put Ups and Colors: Item # Putup Ship Weight Color 29502 010100 100 FT 32.300 LB BLACK Notes Item Desc 29502 0101000 1,000 FT 301.000 LB BLACK CZ #12/4C XLPE SHPVC 29502 010250 250 FT 76.500 LB BLACK CZ #12/4C XLPE SHPVC 29502 010500 500 FT 157.500 LB BLACK CZ #12/4C XLPE SHPVC 29502 0105000 5,000 FT 1,500.000 LB BLACK CZ #12/4C XLPE SH PVC #12/4C XLPE SH PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 5 Revision Date: 04-04-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
29502 010250 价格&库存
很抱歉,暂时无法提供与“29502 010250”相匹配的价格&库存,您可以联系我们找货
