3072F C551000
3072F C551000
    BELDEN
    CBL 1PR 18AWG SHLD
3072F C551000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3072F Twinax - DataTray® 600V Twinaxial Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (7x26) tinned copper conductors, flame-retardant polyolefin insulation, overall Beldfoil® (100% coverage) plus a tinned copper braid shield (55% coverage), sunlight resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 18 7x26 TC - Tinned Copper .046 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) FRPO - Flame Retardant Polyolefin .096 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 55 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 7x28 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.324 in. Pair Pair Color Code Chart: Number Color 1 Natural 2 Blue Pair Lay Length & Direction: Lay Length (in.) 1.750 Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 75°C Dry Bulk Cable Weight: 48 lbs/1000 ft. Max. Recommended Pulling Tension: 85 lbs. Min. Bend Radius/Minor Axis: 3.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, ITC, PLTC, TC CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3072F Twinax - DataTray® 600V Twinaxial Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes PMSHA Specification: P-MSHA SC-182/7 Flame Test UL Flame Test: UL1685 UL Loading C(UL) Flame Test: FT4 IEEE Flame Test: 1202 Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 78.000 Nom. Inductance: Inductance (µH/ft) .12 Nom. Mutual Capacitance: Capacitance (pF/ft) 19.5 Nominal Velocity of Propagation: VP (%) 64.5 Nominal Delay: Delay (ns/ft) 1.58 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.9 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.2 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .52 10 1.98 50 3.78 100 5.35 200 7.57 400 10.7 Max. Operating Voltage - UL: Voltage 600 V RMS (NEC Type TC) 300 V RMS (NEC Type PLTC) 300 V RMS (NEC Type CMG) Notes (Overall) Notes: For CPE jacketed version order Part No. YM45044. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc MD1810 C551000 1,000 FT 69.000 LB BLUE, CAIRO C #18 FS PR FRPP SH PVC Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3072F Twinax - DataTray® 600V Twinaxial Cable 3072F C551000 1,000 FT 69.000 LB BLUE, CAIRO C #18 FS PR FRPP SH PVC 3072F C5510000 10,000 FT 710.000 LB BLUE, CAIRO CN #18 FS PR FRPP SH PVC 3072F C55250 250 FT 17.500 LB BLUE, CAIRO C TRANSFER REVIEW (20 TO 30) 3072F C552500 2,500 FT 177.500 LB BLUE, CAIRO C #18 FS PR FRPP SH PVC 3072F C55500 500 FT 35.000 LB BLUE, CAIRO CN #18 FS PR FRPP SH PVC 3072F C555000 5,000 FT 345.000 LB BLUE, CAIRO C #18 FS PR FRPP SH PVC Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 08-01-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
3072F C551000 价格&库存
很抱歉,暂时无法提供与“3072F C551000”相匹配的价格&库存,您可以联系我们找货
3072F C551000
  • 1000+57.071211000+7.11703
3072F C551000
  • 1+133.746731+16.67880
  • 50+105.9281350+13.20970
  • 100+94.69196100+11.80850
  • 305+83.63701305+10.42990
