3082A T5U500
3082A T5U500
    BELDEN
    CBL 1PR/15AWG 1PR/18AWG SH
3082A T5U500 数据手册
Part Number: 3082A DeviceBus® for ODVA DeviceNet™, (1 pr) 15 AWG (19x28) TC & (1 pr) 18 AWG (19x30) TC, PVC/PVC & FPE/PVC, Foil+TC Braid Shld, CMG, PLTC-ER Product Description One 15 AWG pair stranded (19x28) tinned copper conductors and one 18 AWG pair stranded (19x30) tinned copper conductors, PVC insulation (power), foam polyethylene (FPE) insulation (data), individual foil shield (100% coverage) plus an overall tinned copper braid (65% coverage), oil- and UV-resistant PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding Material No. of Pairs 15 19x27 TC - Tinned Copper 1 18 19x30 TC - Tinned Copper 1 Conductor Count: 4 AWG Size: 15 Insulation Element Material Nominal Wall Thickness 15 PVC - Polyvinyl Chloride 18 FPE - Foamed Polyethylene 0.053 in 0.021 in Color Chart Number Color 1 (15 AWG) Red & Black 2 (18 AWG) Blue & White Inner Shield Material Type Material Coverage [%] Tape Aluminum Foil-Polyester Tape 100 % Outer Shield Material Type Material Coverage [%] Drainwire Material Braid TC - Tinned Copper 65 % Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 18 Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.48 in 0.06 in Construction and Dimensions Stranding Lay Length 1 MHz Electrical Characteristics Conductor DCR Element Nominal Conductor DCR Nominal Outer Shield DCR 15 AWG 3.6 Ohm/1000ft 18 AWG 6.9 Ohm/1000ft 1.8 Ohm/1000ft 19x30 mm Capacitance Element Nom. Capacitance Conductor to Conductor 18 AWG Pair Only 12 pF/ft Inductance Element Nominal Inductance 15 AWG Pair Only 0.174 µH/ft Impedance Nominal Characteristic Impedance 120 Ohm Delay Max. Delay Max. Delay Description Nominal Delay Nominal Velocity of Propagation (VP) [%] Nominal Velocity of Propagation (VP) Description 1.36 ns/ft 18 AWG Pair Only 18 AWG Pair Only 1.36 ns/ft 75 % High Freq Element Frequency [MHz] Max. Insertion Loss (Attenuation) Max./Min. Input Impedance (unFitted) 18 AWG Pair Only 0.125 MHz 0.13 dB/100ft 0.5 MHz 0.25 dB/100ft 1 MHz 0.36 dB/100ft Current Element Max. Recommended Current [A] 15 AWG 8.0 Amps 18 AWG 5.0 Amps Voltage UL Voltage Rating 300 V RMS 600 V RMS 300 V RMS (C(UL) AWM) Temperature Range UL Temp Rating: 75°C Operating Temp Range: -20°C To +75°C Mechanical Characteristics Oil Resistance: Yes Bulk Cable Weight: 108 lbs/1000ft Max Recommended Pulling Tension: 190 lbs Min Bend Radius/Minor Axis: 4.8 in Standards NEC Articles: 800 NEC/(UL) Specification: CMG, PLTC-ER CEC/C(UL) Specification: CMG UL AWM Style: 20201 CSA AWM Specification: AWM I/II A CPR Euroclass: Eca Other Specification: ODVA Class 2 Thick Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes 120 Ohm EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Oil Resistance: Yes Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 FT4 Loading CSA Flammability: FT4 Part Number Plenum (Y/N): No Variants Item # Color Footnote 3082A T5U1000 GRAY T5U C 3082A T5U2000 GRAY T5U C 3082A T5U3000 GRAY T5U 3082A T5U500 GRAY T5U C Footnote: C - CRATE REEL PUT-UP. Product Notes Notes: Thick. Meter marks on jacket to aid users in installation. ODVA DeviceNet is an Open DeviceNet Vendor Associatio, Inc. Trademark. Jacket printed ""1PR16"" instead of ""1PR15"" due to UL requirements for CMG Listing. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
3082A T5U500 价格&库存
很抱歉,暂时无法提供与“3082A T5U500”相匹配的价格&库存,您可以联系我们找货
3082A T5U500
  • 500+107.25325500+13.87260
