3106A.00305
3106A.00305
    BELDEN
    BELDEN - 3106A.00305 - Multipair Cable, EIA RS-485, Screened, 1 Pair, 22 AWG, 1000 ft, 305 m
3106A.00305 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3106A Multi-Conductor - EIA Industrial RS-485 PLTC/CM For more Information please call 1-800-Belden1 Description: 22 AWG stranded (7x30) tinned copper conductors, Datalene® insulation, twisted pairs, overall Beldfoil® shield (100% coverage) plus a tinned copper braid (65% coverage), drain wire, UV resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material Dia. (in.) 1 1 22 7x30 TC - Tinned Copper .030 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® FHDPE - Foam High Density Polyethylene Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Braid TC - Tinned Copper 65.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 7x30 TC - Tinned Copper Outer Shield Drain Wire Diameter: .030 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cabling Overall Cabling Color Code Chart: Number Color 1 White/Orange Stripe 2 Orange/White Stripe 3 Blue/White Stripe Overall Nominal Diameter: 0.300 in. Pair Pair Lay Length & Direction: Lay Length (in.) 3.000 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 48 lbs/1000 ft. Max. Recommended Pulling Tension: 65 lbs. Page 1 of 3 05-10-2011 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3106A Multi-Conductor - EIA Industrial RS-485 PLTC/CM Min. Bend Radius (Install)/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs CEC/C(UL) Specification: CM EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .203 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 11.0 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 20.9 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.7 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.8 Nom. Attenuation: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Attenuation (dB/100 ft.) 1 .5 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.7 Amps per conductor @ 25°C Input/Unfitted Impedance: Page 2 of 3 05-10-2011 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3106A Multi-Conductor - EIA Industrial RS-485 PLTC/CM Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Impedance (Ohm) 1 120 Notes (Overall) Notes: Oil Resistance: Passes Oil Res II Per UL1277, Table 10.17. For CPE jacketed version order YR46721. Related Documents: No related documents are available for this product Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 3106A 0101000 1,000 FT 47.000 LB BLACK C #22 FS PR,1#22PVCBRDPVC 3106A 010500 500 FT 25.000 LB BLACK C #22 FS PR,1#22PVCBRDPVC 3106A 0105000 5,000 FT 230.000 LB BLACK CN #22 FS PR,1#22PVCBRDPVC Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 12-05-2008 © 2011 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 05-10-2011
3106A.00305 价格&库存
很抱歉,暂时无法提供与“3106A.00305”相匹配的价格&库存,您可以联系我们找货
3106A.00305
  • 1+107.356391+13.93290
  • 50+84.7183950+10.99490
  • 100+75.75026100+9.83100
  • 305+66.78212305+8.66710
库存:230
