433945.001
433945.001
    BELDEN
    BELDEN - 433945.001 - Coaxial Cable, RG6, 18 AWG, 75 ohm, 328 ft, 100 m
433945.001 数据手册
TECHNICAL DATA SHEET 433945 RG6 code version 1 date 2004-05-17 page 1/2 APPLICATION ANALOG VIDEO/CCTV. SUITABILITY Indoor. CONSTRUCTION 1. COAX 6/U 1.1. Conductor nominal conductor diameter Material 1.02 mm (AWG18) solid bare copper 1.2. Dielectric Material Nominal diameter over dielectric Foamed PE 4.57 mm 1.3. Shield Type Material Coverage Braid Bare – Cu 95% 3. Sheath Material Colour Nominal thickness of sheath Nominal diameter over sheath FRNC Grey 0.70 mm 6.75 mm ELECTRICAL REQUIREMENTS AND TEST METHODS COAX Nom. characteristic impedance 75 Ω Nominal resistance conductor 21 Ω/km Nominal resistance shield 16.4 Ω/km Nom. capacitance cond. to shield 53.4 pF/m Nominal delay 4.0 ns/m Nominal velocity of propagation 83 % Testvoltage conductor-conductor 2500 VDC, 3 seconds Testvoltage conductor-screen 2500 VDC, 3 seconds Voltage rating 300 V RMS © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner code version 1 date 2004-05-17 page 2/2 TECHNICAL DATA SHEET 433945 RG6 Freq. (MHz) Nom. Att. (dB/100 m) 1 10 50 0.78 2.10 4.92 100 6.56 Mechanical and physical: Flame resistance Temperature range processing and operating Temperature range storage Minimum bending/setting radius Maximum pulling tension 200 9.51 400 13.8 700 18.4 900 21.0 1000 23.0 u.c. -30 to +70 ˚C -30 to +70 ˚C 10*D/5*D 30N MARKING NEW GENERATION(R) BY BELDEN 433945 HALOGEN FREE 1C18 70C +sequential length marking © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
433945.001 价格&库存
很抱歉,暂时无法提供与“433945.001”相匹配的价格&库存,您可以联系我们找货
