4502FE.00100
4502FE.00100
    BELDEN
    BELDEN - 4502FE.00100 - Multicore Cable, Security Alarm, Screened, 4 Core, 22 AWG, 0.352 mm², 328 ft...
4502FE.00100 数据手册
TECHNICAL DATA SHEET concept 4502FE NON-PAIRED code version 1 date 2004-04-27 page 1/2 APPLICATION Intercom/PA Systems, Sound/Audio Systems. CONSTRUCTION 1. 2. 3. 4. 4. Conductor Diameter of conductor Material 0.75mm (AWG22) stranded bare copper (7xAWG30) Insulation Material Diameter over insulation Wallthickness PE 1.25 ± 0.05 mm 0.25 mm Overall Cabling Colour code Outer shield Shield Shield Material Shield Thickness Alu Shield coverage Drainwire black-red-white-green Beldfoil®) Aluminium / Polyester tape 9 µm 100% AWG24 (7xAWG32) tinned Cu Sheath Material Colour Nominal thickness of sheath Diameter over sheath FRNC Grey 0.38 mm 3.9 ± 0.30 mm REQUIREMENTS AND TEST METHODS Electrical: Nominal resistance conductor Nominal resistance shield Nom. capacitance conductor to conductor @ 1kHz Nom. capacitance cond. to shield + other cond. @ 1kHz Testvoltage conductor-conductor Testvoltage conductor-screen Voltage rating Maximum continues current per conductor @ 25 °C 54 Ω/km 52.8 Ω/km 105 pF/m 185 pF/m 2500 VDC, 3 seconds 2500 VDC, 3 seconds 300 V RMS 2.2 A per conductor @ 25 ˚C © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET concept 4502FE NON-PAIRED Mechanical and physical: Temperature range processing and operating Temperature range storage Minimum bending/setting radius Maximum pulling tension Halogen free according to Non dense smoke according to Non corrosive gas according to Flame Retardant according to code version 1 date 2004-04-27 page 2/2 -20 to +70 ˚C -30 to +70 ˚C 5*D/10*D 20 N IEC 60754-1 IEC 61034-1 and 61034-2 IEC 60754-2 IEC 60332-1 MARKING NEW GENERATION(R) BY BELDEN 4300FE HALOGEN FREE 70C 4C22 SHIELDED + sequential meter marking. © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
4502FE.00100 价格&库存
很抱歉,暂时无法提供与“4502FE.00100”相匹配的价格&库存,您可以联系我们找货
