5000FE 008500
5000FE 008500
    BELDEN
    BELDEN - 5000FE 008500 - SHIELDED MULTICONDUCTOR CABLE, 2 CONDUCT
5000FE 008500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5000FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled For more Information please call 1-800-Belden1 General Description: Security & Commercial Audio Cable, Riser-CL3R-FPLR, 2-12 AWG stranded bare copper conductors with Polyolefin insulation, Beldfoil® shield and PVC jacket with ripcord Usage (Overall) Suitable Applications: Intercom/PA Systems, Sound/Audio Systems, Fire Alarm Systems (For color Red only) Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 12 19x25 BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene 0.011 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 (7x28) TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.017 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Lay Length & Direction: Length (in.) Direction Twists (twist/ft) 3.500 Left Hand 3.400 Overall Cabling Color Code Chart: Number Color 1 Black 2 White Overall Nominal Diameter: 0.264 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 62.500 lbs/1000 ft. Max. Recommended Pulling Tension: 182.400 lbs. Min. Bend Radius/Minor Axis: 2.625 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL3R, FPLR NEC Articles: 725, 760 EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5000FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 6000FE Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) 0.140 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 64.000 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 115.250 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.6 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 7.100 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature Rise 12 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 5000FE 0021000 1,000 FT 59.000 LB RED C 2 #12 PP FS FRPVC 5000FE 0081000 1,000 FT 59.000 LB GRAY C 2 #12 PP FS FRPVC 5000FE 008500 500 FT 29.500 LB GRAY C 2 #12 PP FS FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 01-20-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5000FE Multi-Conductor - Commercial Audio Systems - 2 Conductors Cabled product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
5000FE 008500 价格&库存
很抱歉,暂时无法提供与“5000FE 008500”相匹配的价格&库存,您可以联系我们找货
