Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
5302UE Multi-Conductor - Commercial Applications
For more Information
please call
1-800-Belden1
General Description:
Security & Commercial Audio Cable, Riser-CMR, 4-18 AWG stranded bare copper conductors with
polyolefin insulation, PVC jacket with ripcord
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
4
18
7x26
BC - Bare Copper
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material Wall Thickness (in.)
PP - Polypropylene 0.008
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.017
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Cabling Lay Length & Direction:
Length (in.) Direction Twists (twist/ft)
4.000
Left Hand 3.000
Overall Cabling Color Code Chart:
Color
Black
Red
White
Green
Overall Nominal Diameter:
0.184 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +75°C
UL Temperature Rating:
75°C
Bulk Cable Weight:
28 lbs/1000 ft.
Max. Recommended Pulling Tension:
90 lbs.
Min. Bend Radius/Minor Axis:
1.800 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
NEC Articles:
800
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
Page 1 of 2
01-05-2017
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
C(UL) Flame Test:
FT4
Plenum/Non-Plenum
Plenum Number:
6302UE
Electrical Characteristics (Overall)
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
22.000
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
6.5
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Description
Current
10C Temperature Rise 4 Amps per conductor @ 25°C ambient
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
5302UE 008U1000
1,000 FT
30.000 LB
GRAY
5302UE 008U500
500 FT
15.500 LB
GRAY
5302UE 0081000
1,000 FT
30.000 LB
GRAY
5302UE 008500
500 FT
15.000 LB
GRAY
Notes
Item Desc
4 #18 PP FRPVC
4 #18 PP FRPVC
C
4 #18 PP FRPVC
4 #18 PP FRPVC
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 08-09-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“5302UE 008U1000”相匹配的价格&库存,您可以联系我们找货
